| tweet |
Jun 26 2017, 08:49 AM
Member ![]() ![]() Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
How much for full lock refurb plus door handels rechromed Thanks B A full service for a complete lock set runs from $590-$640. The price varies on which model/year you have. The ignition locks have different pricing as seen above, for reference. This does not include chrome. Currently we are offering Concours quality show chrome, but the service is very expensive so we are offering a lower cost alternative; handle replacement (not included in this quoted pricing; additional). With Forum Member Discount, prices drop $49-$54. The full service includes: Full disassembly of all lock assemblies/reassembly Deep cleaning and treatment for oxidation Inspection for condition and comprehensive condition report to customer Strip and refinish t-handle assembly with black self etching primer and epoxy paint Cold galvanize all cams (3) Replace door handle nylon cams (2) Replace internal seals (4) High polish trunk, lock brass retaining nut Polish glove glove lock retaining nut Replace all mounting hardware (3) Rebuild all lock cylinders with new brass tumblers and springs (6) Polish all steel face caps and collar (5) New lube Decode/cut to code keys New Porsche OEM Master blank plus cut New Porsche OEM Valet blank plus cut Quality control check (on 914-6 drill steering lock housing to remove embedded roll pin) |
| tweet |
Jul 4 2017, 01:45 PM
Another order we recently finished up for a customer. This owner is hands on and is doing some of the lock work himself, but needed a hand up. That's okay with us because we will work with customers' parts based on their need; anything we can help with we will. He has a NOS 75-76 ignition lock and wanted us to match his lock cylinders to his NOS ignition key. We also replaced missing valet tumblers for the t-handle, cleaned, lubed and polished all the parts. We then rebuilt the lock cylinders and cut new keys.
Attached thumbnail(s) |
| tweet |
Aug 4 2017, 06:03 AM
This is a lock set we refurbished recently. This time we have some close ups of our keying and what a proper rekey should look like. Notice all of the tumblers are flush at the shear line. And no, no tumbler grinding is necessary to get them to seat properly.
| tweet |
Aug 14 2017, 02:44 PM
Here are some keys we made to code for a 911 customer. Even when your keys are not good candidates for duplication, new keys can be made to your code. Don't know your code, not to worry we can decode your keys and locks. This key was bowed and bent; compare to the new master and valet on either side.
| tweet |
Aug 14 2017, 02:54 PM
This was an order we did for a member. Although it wasn't a complete lock set, this job did present quite a challenge. We brought these locks back from the brink. They had substantial condition issues, damage and wear. The ignition was rebuilt, the steering lock cleaned and lubed to prevent jamming and the door handle was repaired. A new key was made and it works smoothly in both the newly rebuilt and existing lock cylinders.
| tweet |
Dec 10 2017, 11:00 AM
Here is some recent work we did for a 914-6 customer. Handle bases were replaced with new after market and the rest of the locks were rebuilt. The client has a nice 914-6 project car and he wanted to keep the locks as original as possible while still working within a budget. So, the after market door handles are a fair compromise for now. They can always be upgraded at a later date since the lock set is now matched and rebuilt to a new set of OEM Porsche keys.
| mepstein |
Dec 10 2017, 11:31 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,961 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have to send you my locks so I can get the 911 ignition switch re-keyed to the 914 key.
So far Dan has: Fixed my motorcycle ignition lock - in pieces, missing pieces, missing key. Fixed the broken ignition lock on my 914 and made a proper key for it. I’m very pleased with the work. |
| tweet |
Dec 10 2017, 03:12 PM
I have to send you my locks so I can get the 911 ignition switch re-keyed to the 914 key. So far Dan has: Fixed my motorcycle ignition lock - in pieces, missing pieces, missing key. Fixed the broken ignition lock on my 914 and made a proper key for it. I’m very pleased with the work. Hello Mark, Sure thing, whenever you are ready. Thank you for the positive feedback. It has been a pleasure handling your lock work. Regards, Dan & Alicia |
| tweet |
Mar 23 2018, 05:33 PM
Here's a rechromed trunk lock we built for a client. We keyed to his master key and now he has something to fill that once empty spot.
(IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
| tweet |
Apr 16 2018, 05:59 PM
Here is another ignition switch saved. This one is going back overseas. The ignition was no longer starting the car and the owner's key was bent. So, we rebuilt the unit and made two new keys to code.
| tweet |
Apr 30 2018, 08:46 PM
This is a set of locks a client sent in for keys and repairs. The client has owned the vehicle for a long time. His ignition switch had the typical electrical failure. So, we rebuilt it . We also serviced his matching handles. The lock set did not have any key code information and the client's key was very worn and twisted. So, we decoded all three locks and were able to cut one new set of keys to operate all three. Now his lock set will perform as it should.
| tweet |
May 5 2018, 01:28 PM
This is a trunk lock that needed some repairs. The client wanted to do some of the work himself to keep costs to a minimum. So, we were happy to assist with his request. We replaced the damaged lock cylinder, tumblers and springs. We replaced the seals and cleaned and lubed. Now he will be able to secure his rear trunk. No job is too small. All of our customers are just as important to us.
| forrestkhaag |
May 6 2018, 07:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Say what you will but a few years past, i bought a 914 sight unseen and every lock and key was missing or not fitting in its appointments....... but tweet came to the rescue... new locks, new ignition and keys to match / and all things right with the valet key properly color coded.
Toss in the spec data to reproduce the keys if needed in the future, and you have a service and vendor that follows thru and produces. I say go Tweet. (IMG:style_emoticons/default/first.gif) |
| tweet |
May 10 2018, 02:51 PM
Say what you will but a few years past, i bought a 914 sight unseen and every lock and key was missing or not fitting in its appointments....... but tweet came to the rescue... new locks, new ignition and keys to match / and all things right with the valet key properly color coded. Toss in the spec data to reproduce the keys if needed in the future, and you have a service and vendor that follows thru and produces. I say go Tweet. (IMG:style_emoticons/default/first.gif) Hello Forrest, Thank you so much for the positive feedback. You rock! (IMG:style_emoticons/default/aktion035.gif) -Alicia and Dan |
| tweet |
May 10 2018, 07:26 PM
Here is a door handle we serviced and rekeyed for a client. We also replaced the internal seal and installed a new nylon cam. When the handle is off the car it is the best time to fully service it. It saves a lot of time in the future and more work taking the door apart again later.
| 914-300Hemi |
Jun 2 2018, 07:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California
Do you rekey 911 locks as well?
| tweet |
Jun 2 2018, 07:37 AM
| tweet |
Dec 9 2018, 12:47 PM
So, we haven't updated our thread in a while. This restoration was a complete overhaul. This restored set is on its way to Kenya. The before and after pics tell the story.
| stevie 77 930 |
Jun 28 2019, 12:26 PM
Newbie ![]() Group: Members Posts: 3 Joined: 1-April 15 From: Chatsworth, CA Member No.: 18,583 Region Association: Southern California |
So, we haven't updated our thread in a while. This restoration was a complete overhaul. This restored set is on its way to Kenya. The before and after pics tell the story. Anyone have any contact with Dan lately? I sent him my trunk lock 2 months ago , fully paid for his services. He quickly acknowledged receipt of payment and receipt of my lock. But now, after several emails both privately and through EBay, I haven't had any replies. Getting a little worrisome |
| FlacaProductions |
Jun 28 2019, 12:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,290 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Not to be too much of a snoop, but using the tools provided here it seems his last log in was 26th June 2019 - 07:55 AM - so...it appears he's around.
Lo-Fi Version | Time is now: 30th October 2026 - 03:16 PM |
