Upgrading the tachometer, to remove that bounce |
timothy_nd28 |
Aug 11 2013, 05:42 PM
First I would like to give thanks to Terry, my uncle, for his time on this and my other RGB backlighting project. He has spent more time working on this than he cares to admit. He's more of a Corvette guy, but his vast knowledge and willingness to help, transcends which benefits our community.
Okay, so I have been told that our tachometer has a problem with bouncing. I personally have never seen this problem and I have to admit that I've never really paid much attention to the tach while driving, so I decided to put the signal generator on the tach and see how it performs. This signal generator bypasses the ignition system and provides a clean signal. This also serves as a control because a bad condenser on the dizzy can cause problems as well. This video shows the untouched tach in its original state running on a function generator. As you will see, it does bounce and over shoot during the sweeps. https://www.youtube.com/watch?v=rbC37l1z_oA This next video shows our tach but with a cheap modern 30 dollar tach stuffed inside. The bounce seems to have disappeared, and there is no more overshoot during the sweeps. https://www.youtube.com/watch?v=cmk1lSop_iE The VDO tach was designed for mass production and had a very simple but effective design. This modern tach uses an air core massless motor which is controlled by sine/cosine inputs which tends to be a bit more responsive and accurate. The original vdo design is a motor/spring contraption which will always have some bounce. Over time, capacitors and dampening fluid may leak or fatigue which will aggravate the problem. In this write up, I will show how to incorporate a off the shelf 30 dollar tachometer commonly found at the auto parts store, and make it work with our VDO gauge can. |
timothy_nd28 |
Sep 20 2014, 12:05 PM
Thanks (IMG:style_emoticons/default/smile.gif) Yes, R9 can be configured from a 2 cylinder to a 32 cylinder. With that said, the variable of the equation would be the 914 tach face. In this thread, R9 was computed for the linearity of our 914 tach. New calculations would be needed for a different style tach face with the number of cylinders desired.
Lo-Fi Version | Time is now: 16th May 2024 - 02:30 AM |
