Upgrading the tachometer, to remove that bounce |
timothy_nd28 |
Aug 11 2013, 05:42 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
First I would like to give thanks to Terry, my uncle, for his time on this and my other RGB backlighting project. He has spent more time working on this than he cares to admit. He's more of a Corvette guy, but his vast knowledge and willingness to help, transcends which benefits our community.
Okay, so I have been told that our tachometer has a problem with bouncing. I personally have never seen this problem and I have to admit that I've never really paid much attention to the tach while driving, so I decided to put the signal generator on the tach and see how it performs. This signal generator bypasses the ignition system and provides a clean signal. This also serves as a control because a bad condenser on the dizzy can cause problems as well. This video shows the untouched tach in its original state running on a function generator. As you will see, it does bounce and over shoot during the sweeps. https://www.youtube.com/watch?v=rbC37l1z_oA This next video shows our tach but with a cheap modern 30 dollar tach stuffed inside. The bounce seems to have disappeared, and there is no more overshoot during the sweeps. https://www.youtube.com/watch?v=cmk1lSop_iE The VDO tach was designed for mass production and had a very simple but effective design. This modern tach uses an air core massless motor which is controlled by sine/cosine inputs which tends to be a bit more responsive and accurate. The original vdo design is a motor/spring contraption which will always have some bounce. Over time, capacitors and dampening fluid may leak or fatigue which will aggravate the problem. In this write up, I will show how to incorporate a off the shelf 30 dollar tachometer commonly found at the auto parts store, and make it work with our VDO gauge can. |
timothy_nd28 |
May 30 2016, 02:22 PM
I have some bad news as it seems that AutoZone has recently jumped ship with their gauge supplier. They're now stocking a tachometer that looks very much like the Sunpro Super Tach II but internally it's nowhere near the same. AutoZone's replacement tachometer called the EQUUS (picture below) is completely digital as it has a micro-controller. Changing a resistor value will have no desirable effect with this tachometer. The SunPro tach is still available thru eBay and Amazon, but it's just a matter of time before this supply dries up too. So a heads up for those contemplating with the current tach upgrade, I would do it soon.
I will mess around with this EQUUS tach, it's still only 30 dollars. I will make available a new DIY for this tach conversion as soon as everything is figured out. With this said, I'm not a computer programmer. The new tach uses a micro controller called "ATTiny 24a". I would need to find out a way to extract the current code (chip is surface mount), then modify the code to work with our 914 gauge face and with 914s with different engines, and finally write the modified code back to the chip. Any programmers willing to help, please chime in or PM me (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:37 AM |
