| jimkelly |
Sep 27 2013, 02:51 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
this is where I saw it mentioned - the warning.
http://www.914world.com/bbs2/index.php?sho...bleeding+brakes |
| jimkelly |
Sep 28 2013, 08:53 AM
well, looks like it is time to tackle vent clearance.
http://www.914world.com/bbs2/index.php?showtopic=82214&hl=adjust+brake ://http://www.914world.com/bbs2/index....l=adjust+brake ://http://www.914world.com/bbs2/index....l=adjust+brake ://http://www.914world.com/bbs2/index....l=adjust+brake just found this http://www.914world.com/bbs2/index.php?sho...l=BRAKE+VENTING and this http://www.914world.com/bbs2/index.php?showtopic=90625 Attached image(s)
| jimkelly |
Sep 28 2013, 09:10 AM
so when adjusting the inner on a car, this is the thing that needs to be turned to adjust inner clearance?
(IMG:http://www.914world.com/bbs2/uploads/post-1110-1228605544.jpg) |
| jimkelly |
Sep 28 2013, 01:58 PM
well, i can get some peddle, but some times peddle still goes to floor.
from top down, my peddle has about 2" of dead movement, then resistance from the MC/etc the rest of the way when it stops from pressure just before hitting the metal, but sometimes peddle still bottoms out. more bleeding needed. also my rear rotors rubbed on my pads, so I started with outer vent adjustment and found a slight adjustment clockwise on L&R outer screws alleviated rubbing/noise. I made this tool from 17mm wrench and 13mm socket. oh, and when I turn the rotors by hand and have my wife step on brake peddle, I get strong stop on all 4. Attached image(s)
Lo-Fi Version | Time is now: 12th August 2026 - 04:53 AM |
