Oooooops!, What did I miss? |
914itis |
Oct 8 2013, 09:58 PM
I was doing very well with my conversion, until installing the shift rod. It's touching the headers. What did I miss?
New shift rod? |
McMark |
Oct 8 2013, 10:00 PM
There MAY be a few people who don't have the exact details of your project memorized. (IMG:style_emoticons/default/rolleyes.gif)
gms |
Oct 8 2013, 10:04 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
If you are talking about installing a side shift rod in a 914/6 conversion you will need to customize the rear shift rod like this
914itis |
Oct 8 2013, 10:06 PM
There MAY be a few people who don't have the exact details of your project memorized. (IMG:style_emoticons/default/rolleyes.gif) Thanks Mark Here is the thread My conversion |
914itis |
Oct 8 2013, 10:09 PM
gms |
Oct 8 2013, 10:22 PM
I had to cut a side shift rod and weld in a 4 cylinder tail shift rod and a little adjustment with a conduit bender
Luke M |
Oct 9 2013, 06:46 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I was doing very well with my conversion, until installing the shift rod. It's touching the headers. What did I miss? New shift rod? Check out the links below it should answer your question. The last link has a lot of info on other 6 conv stuff also. http://www.914world.com/bbs2/index.php?showtopic=142395 http://www.914world.com/bbs2/index.php?showtopic=114741 http://www.914world.com/bbs2/index.php?showtopic=112239 |
jimkelly |
Oct 9 2013, 07:12 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I just made one - straight and longer - for my v8.
see post#16 - the thick metal is a joy to weld - sheet metal - not so much. http://www.914world.com/bbs2/index.php?showtopic=219911 I have a spare tail shift bar if you need it - pictured below Attached image(s) |
914itis |
Oct 9 2013, 08:25 AM
I just made one - straight and longer - for my v8. see post#16 - the thick metal is a joy to weld - sheet metal - not so much. http://www.914world.com/bbs2/index.php?showtopic=219911 I have a spare tail shift bar if you need it - pictured below Thanks Jim. I think I have one if I didn't throw it away last week (IMG:style_emoticons/default/headbang.gif) I think (IMG:style_emoticons/default/welder.gif) is on my future. If I find the rod, I can take care of that this evening. If not, get ready to ship Jim. I should know in an hr. |
jimkelly |
Oct 9 2013, 09:29 AM
I await your update.
I also have this 39.25" Attached image(s) |
914itis |
Oct 9 2013, 09:36 AM
jimkelly |
Oct 9 2013, 09:39 AM
cool - I have to double check the welds of the one on my car - as this bar need as a lot of heat from the mig. finally saw an actual weld puddle today playing with the above bar.
an double check length, don't go off my 39.25" measurement. |
gms |
Oct 9 2013, 11:41 AM
Jeffs9146 |
Oct 9 2013, 11:45 AM
From my understanding, the rod must be straight , no curves? In my experience having a curve in it make the plunging action better at the rear shift console I left a small curving in mine and it works well but it was harder to get the curve in the correct spot so it didn't hit the header! Attached thumbnail(s) |
914itis |
Jeffs9146 |
Oct 9 2013, 12:02 PM
From my understanding, the rod must be straight , no curves? In my experience having a curve in it make the plunging action better at the rear shift console Should I cut the tail shift bar before the curve? What do you think? If you are doing it alone you should go straight because if you go curved it will take two people to get it aligned so it doesn't hit with the header or oil tubes. I installed the two cut off ends. Then I tacked the center section in place and had my friend run through the gears while I watched to make sure every gear went in all the way and didn't hit any thing! It took 3 tries to get it perfect. With the straight bar you just need to make sure the two cone screws are aligned and the proper length so you can do it on the bench! |
914itis |
Oct 9 2013, 12:08 PM
Thanks, straight it is.
Jgilliam914 |
Oct 9 2013, 12:25 PM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
From our own RacerChris at Tangerine racing http://www.tangerineracing.com/index_htm_files/1052.jpg
jimkelly |
Oct 9 2013, 12:26 PM
here is a video of me shifting thru the gears with straight bar.
good thing I did this - did not realize how loose my engine and trans are - whew. seems to me, curves should make no difference. sounds like my shifter could use some grease : ) http://youtu.be/MEZGsCXrBCw |
Lo-Fi Version | Time is now: 19th May 2024 - 12:12 AM |
