PIX, Pix Of Enlightenment |
veekry9 |
Oct 15 2013, 07:37 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
veekry9 |
Sep 14 2014, 02:19 PM
T603 engine designed by Julius Mackerle. http://www.eurospares.com/graphics/engine/...searcheable.pdf (thanks jd74914 ) By raising the camshaft far above the crank in the valley,the rocker geometry for the exhaust valve is improved,perhaps making possible the use of common rockers throughout. Note the hemi-like chamber and wide angle canted valves.Like the VW/Porsche and Corvair,the bore diameter is restricted by the cylinder head studs. A considerable amount of weight savings would be realized by adopting LN cylinders. I believe the crank is a conventional cross plane and at a small 72mm stroke,there may be plenty of room for a much larger stroker. http://www.velocetoday.com/a-technical-history-of-tatra/ The discrete lifter-blocks allow replacement roller-lifter and barrels to be installed for low friction,high rpm operation. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:02 PM |
