Where are all the chassis number stamps located? |
rick 918-S |
Nov 10 2013, 08:29 AM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I know one is on the right upper inner panel and one is located on the right side of the trunk floor pan. Of course there is the pillar tag in the door jamb. But where else?
The reason I'm asking is in preparation of the work I will be doing on the 6. I don't want to accidentally cut out or through anything that has a number stamping. (IMG:style_emoticons/default/sawzall-smiley.gif) |
Nov 10 2013, 08:30 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Something up under the dash...but I recall that would be hand written.
You should see if you can locate and read the thread from BR and Andy when they disected the prototype. That came up...with tons of photos. |
rick 918-S |
Nov 10 2013, 08:31 AM
Something up under the dash...but I recall that would be hand written. Ok, I'm good there. I'll be stopping way short of the dash. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/smile.gif) |
Nov 10 2013, 08:33 AM
Up front, inner passenger fender...stamped.
Then again, inner passenger fender, pop riveted plate. Not sure about what year had what plate and where it was....that changed a few times. |
rick 918-S |
Nov 10 2013, 08:38 AM
Up front, inner passenger fender...stamped. Then again, inner passenger fender, pop riveted plate. Not sure about what year had what plate and where it was....that changed a few times. Yep, the riveted plate is intact and located on the bumper brace. Only riveted so it's an easy save. |
toolguy |
Nov 10 2013, 08:51 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
On a six, the trunk floor number is located in the center behind where the lock goes about 6 inches in. . . .
there are no other stamped ones other than the one in the front pass. fender liner. . then the front tag and the drivers window tag, the hole is the center muffler shield mount for reference Attached image(s) |
rick 918-S |
Nov 10 2013, 09:07 AM
On a six, the trunk floor number is located in the center behind where the lock goes about 6 inches in. . . . there are no other stamped ones other than the one in the front pass. fender liner. . then the front tag and the drivers window tag, the hole is the center muffler shield mount for reference That's good to know. I hadn't looked yet and just assumed the 6 had the same trunk stamp location as the 4. |
McMark |
Nov 10 2013, 11:48 AM
The front trunk vin tag is on the bumper support? Post a pic of that. Doesn't sound right. Should be on the headlight bucket.
Nov 10 2013, 12:36 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
But where else? VIN locations: http://www.914world.com/bbs2/sources/actio...op_helpvin.html Chassis Number locations: http://www.914world.com/bbs2/sources/actio...elpchassis.html Build Date locations: http://www.914world.com/bbs2/sources/actio...p_helpdate.html Paint Code locations: http://www.914world.com/bbs2/sources/actio..._helppaint.html (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
Nov 10 2013, 01:17 PM
The front trunk vin tag is on the bumper support? Post a pic of that. Doesn't sound right. Should be on the headlight bucket. Brain fade... It was on the HL bucket. (IMG:style_emoticons/default/screwy.gif) |
shoguneagle |
Nov 10 2013, 03:21 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
do not cut out or paint over the fed sticker regarding import, smog(?), etc. This usually found on the left bottom rear door sill and you would be surprised how many people destroy/paint over this sticker.
Steve |
carr914 |
Nov 10 2013, 04:52 PM
Racer from Birth Group: Members Posts: 118,882 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
On a six, the trunk floor number is located in the center behind where the lock goes about 6 inches in. . . . there are no other stamped ones other than the one in the front pass. fender liner. . then the front tag and the drivers window tag, the hole is the center muffler shield mount for reference (IMG:style_emoticons/default/agree.gif) |
doug_b_928 |
Nov 10 2013, 04:55 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I've always been curious about this: what if there are some rust bubbles under the sticker? Is there some way to salvage it?
scotty b |
Nov 10 2013, 06:29 PM
I've always been curious about this: what if there are some rust bubbles under the sticker? Is there some way to salvage it? Chances are no, but you could try and score the paint a half inch or so away from the stickers edge and try to peel the paint off with the sticker still attached. Then you could scrape the paint off the sticker and reglue it (IMG:style_emoticons/default/confused24.gif) FWIW, I would go into this process assuming it will not work |
Eric_Shea |
Nov 10 2013, 06:36 PM
PMB Performance Group: Admin Posts: 19,277 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
doug_b_928 |
Nov 10 2013, 07:01 PM
Great, thanks guys!
walterolin |
Nov 10 2013, 08:01 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
do not cut out or paint over the fed sticker regarding import, smog(?), etc. This usually found on the left bottom rear door sill and you would be surprised how many people destroy/paint over this sticker. Steve SoCalAndy makes exact duplicates. Had a problem with Andy. Long story. He cashed my $90.00 check and never sent the sticker, after promising to send it with delivery confirmation. He doesn't respond to PMs. Walter Olin |
rick 918-S |
Nov 10 2013, 11:31 PM
do not cut out or paint over the fed sticker regarding import, smog(?), etc. This usually found on the left bottom rear door sill and you would be surprised how many people destroy/paint over this sticker. Steve SoCalAndy makes exact duplicates. Had a problem with Andy. Long story. He cashed my $90.00 check and never sent the sticker, after promising to send it with delivery confirmation. He doesn't respond to PMs. Walter Olin Completely shocked to read this. I know Andy. He's a stand up guy. Lets get his side too. |
Lo-Fi Version | Time is now: 30th May 2024 - 09:07 AM |
