16"x7 Fuchs Narrow, 16" fuchs fitment w/ stock 914 body |
campbellcj |
Feb 27 2014, 08:10 PM
I can't Re Member Group: Members Posts: 4,546 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
That's an interesting, cool solution. If not hung up on having OE Fuchs there are also good quality aftermarket wheels that can be ordered in custom offsets. For example I just got some Braid "Fuchs-style" wheels that are really nice, and available in countless measurements and finishes.
cgnj |
Feb 27 2014, 09:32 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
Looks like the fender lip has been rolled up. Now visualize needing another 1.5 inches minimum. Carlos |
Alapone |
Feb 28 2014, 06:36 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
What do you mean by adding an inch to the inside? spacer? sorry still new to alot of this. The wheels I am talking about are off an 85' carerra not sure if that narrows down offset. |
ConeDodger |
Feb 28 2014, 07:06 AM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Sometimes wheel workers such as Jeff Hines or Harvey Weidman add an inch or so to a set of wheels. My own car is flared and has 8.5X16 RSR Fuchs in the rear made from 4-16X6 Fuchs. Cut and welded to change the offset.
Zaney |
Feb 28 2014, 10:54 AM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
I started out thinking I would keep it it simple and just roll mine but, I got carried away (IMG:style_emoticons/default/beer.gif)
MoveQik |
Feb 28 2014, 12:23 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I would go with 16x6's as the no brainer. They look great. They fit with zero troubles and they are easy to find. Here is mine before I went through all of the headache and expense of pulling the fenders for wider wheels. IMHO, there is no quick, cheap or easy way to pull the fenders if you want it to look right. If someone tells you they can just roll a bat under there and stretch them, run away quickly.
Lo-Fi Version | Time is now: 28th May 2024 - 02:15 PM |
