LEDs For Front Turnsignal Bucket |
Spoke |
Mar 30 2014, 09:35 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
On the radar are LED boards for the front turnsignal bucket. LEDs would be pointing directly to the front of the car to focus optical energy forward.
There are 3 versions I can think of: 1) US lens: All amber LEDs; all on low for running lights; on high for turnsignals. 2) Euro lens: White LEDs on the lower section; on for running lights; amber for turnsignals. White LEDs would turn off when turnsignals are on. 3) Clear lens: White running LEDs on the outside of the lens; Amber LEDs in the center for turnsignals. White LEDs would turn off when turnsignals are on. Which versions would folks want? I think I would like the clear lens. The oval running lights would be unique. Mock up of turnsignal LED PCB. PCB for clear lens. PCB for Euro lens. |
mikesmith |
Aug 4 2014, 11:21 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Rather than bend the leads, just increase the drill size so that the LED sits naturally in the hole at the right angle. Build a jig to hold the board tilted so the LEDs flop over.
This would be a nuisance to set up if you were wave soldering (you'd want a different jig that secured the LEDs at the correct angle), but assuming you're still assembling these by hand (you masochist) it should be simple. With this layout, the low side of the LED should be touching the board, so a generous coating of conformal will bind the LEDs to the board, giving you the mechanical strength you wanted. Also, +1 for a set of the Euros. |
Lo-Fi Version | Time is now: 26th May 2024 - 02:34 AM |
