LEDs For Front Turnsignal Bucket |
Spoke |
Mar 30 2014, 09:35 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
On the radar are LED boards for the front turnsignal bucket. LEDs would be pointing directly to the front of the car to focus optical energy forward.
There are 3 versions I can think of: 1) US lens: All amber LEDs; all on low for running lights; on high for turnsignals. 2) Euro lens: White LEDs on the lower section; on for running lights; amber for turnsignals. White LEDs would turn off when turnsignals are on. 3) Clear lens: White running LEDs on the outside of the lens; Amber LEDs in the center for turnsignals. White LEDs would turn off when turnsignals are on. Which versions would folks want? I think I would like the clear lens. The oval running lights would be unique. Mock up of turnsignal LED PCB. PCB for clear lens. PCB for Euro lens. |
euro911 |
Aug 8 2014, 05:25 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Jerry, if the upper end of the board sits further down in the bucket, why not just supply a stand-off and a long screw for the upper end? ... or am I missing something ?
Spoke |
Aug 12 2014, 03:33 PM
Jerry, if the upper end of the board sits further down in the bucket, why not just supply a stand-off and a long screw for the upper end? ... or am I missing something ? I'm planning to mount these with brass sheet material like I started on the rear lights. I want to use the existing 2 screws for the lens cover to secure the board. As with the rears, the goal is to make no modifications, drilling, or wire changes to the bucket or lens. I wanted the board to be flush with the bucket angle. This first pair will sit lower in the rear but will work just fine. Just doesn't look as nice as I would like it to. I need to make a jig that is slightly thinner than the one I used for the first board. |
Lo-Fi Version | Time is now: 26th May 2024 - 02:38 AM |
