Wheel/Tire Fitment on narrow car, fuchs 16*6 and 16*7 with 205/40/16 |
Alapone |
Aug 26 2014, 09:35 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Hello all,
I know this topic has been beaten to death but one more time couldn't hurt right? I am nearing the end of my part collecting odyssey for 5 lug conversion and am now wondering on tire fitment on my narrow car. I have fuchs 16x6 and 7 and originally purchased falken azenis 205/40/16 size tires to go with the setup. Now that I am older and wiser I am wondering the following..... - Will my 205/40s fit under the narrow rears with a redrilled hub rotor 914-4 setup on the 7" rim? - Will 205/ 40s fit on a 7" rim at all? - If they will do I want to run this low a profile tire (82mm)? - Can I squeeze more tire under the rears 215/50 225/50 (without manipulating fenders) - I am told I will have to work the fenders to fit 7s at all. If this is the case should I just get the 215s or 225 I want and work the fenders accordingly? - From a car value standpoint I have to assume on 75' 2.0, the added value of a 911 suspension set up should offset any negative effects of the rolled/pulled fenders. Is this correct thinking? I know these cars are becoming collectable but I'm not really hurting myself here right? - I am thinking of Dunlop direzza 215/50/R16 as the compromise can I do this. I know 16x6s all around is the pain free path.......but that extra inch in the back is just so cool....AND I have em already. Any help would be much appreciated. Thanks Andrew |
smj |
Aug 26 2014, 02:01 PM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
FWIW, I've got 6 & 7x16 Fuchs from an '86 Carrera on my 914-6. The rear fenders don't appear to have been pulled, rolled, or what have you. Rubbed to the point of heating up the paint, thanks to 225s a PO insisted on running... (IMG:style_emoticons/default/dry.gif)
So I believe you've got different stub axles, wheel hubs and brakes, and weight. But I don't know if those really change the dimensions in the wheel wells more than the car-to-car variations seen in the wild. I've had Yoko AVS ES100s in 205/55WR16 at all four corners since I bought it. I hear some rubbing in the front at full steering lock on fire roads and such, that's it. I can fit a finger between the rear tires and the fenders at the top. Hope that helps! |
Lo-Fi Version | Time is now: 15th May 2024 - 07:27 AM |
