Wheel spacers |
Wheel spacers |
partwerks |
Oct 28 2014, 07:15 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
For a 5 lug, is there any specific size for a wheel spacer, other than maybe the depth?
I may be looking at some spacers for the front, to bump out the tire. |
matthepcat |
Oct 28 2014, 08:38 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
5x130 bolt pattern and how thick you want.
Chris914n6 |
Oct 28 2014, 09:06 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Porsche specific will have the inner ring lip sized to match the Porsche wheels. 71.6mm iirc. And the outer diameter will match the hub diameter so it looks flush.
1/4" will fit stock lugs. 1/2"+ will need longer studs and 1"-2" will technically be adapters with their own nuts and studs. Lastly, check fender clearance with the wheel turned and consider hitting a bump /lean. |
mskala |
Oct 29 2014, 07:57 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Also you will need to buy longer studs.
matthepcat |
Oct 29 2014, 08:31 AM
Plenty of OEM wheel spacers available from junk yards or ebay.
Kansas 914 |
Oct 29 2014, 08:36 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
griffindoug |
Nov 24 2014, 10:53 PM
Newbie Group: Members Posts: 45 Joined: 24-June 14 From: Austin TX Member No.: 17,539 Region Association: Southwest Region |
Also you will need to buy longer studs. I have 1" spacers up front on my car and went to 80mm studs on the rotor. I have about 3/4" space between the tire and the fender now. I am curious here, I want to put on flares, and currently am running 195/60/15. Can I put on flares and run spacers to fill out the space or is that a bad idea. I would love some input and help. budget tight as I am having my engine rebuilt by fat performance. I am vinyl wrapping the car and want to put the flares on before I wrap it. No budget left for new rims and rubber. Thoughts? Thanks |
Larmo63 |
Nov 25 2014, 12:28 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
'No budget" isn't going to get much done.
These 5 lug conversions and body modifications are getting more and more expensive by the day. |
MoveQik |
Nov 25 2014, 10:30 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
For a 5 lug, is there any specific size for a wheel spacer, other than maybe the depth? I may be looking at some spacers for the front, to bump out the tire. FWIW, I originally ran 1" spacers with my 16x6 Fuchs with stock fenders. It was tight but it fit and the stance was perfect IMHO. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:29 PM |
