Need to borrow a part, blower motor seal |
McMark |
Feb 15 2005, 12:57 AM
Bruce (GWN7) is looking to recreate the seal that goes between the blower motor intake and the body. I'm hoping someone has a spare housing that has a good seal that we can use to take a mold off of. Can anyone help?
eeyore |
Feb 15 2005, 09:50 AM
Good gawd. Is that the doo-dad that is up under the front cowl?
Trekkor |
Feb 15 2005, 10:09 AM
I may have one for you on Sunday evening.
KT |
Doug Leggins |
Feb 15 2005, 11:20 AM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I have one of each style. One to use with the screen guard and one for use without the screen guard. They are intact but do have cracking due to their age. I can take pics tonight and post them. If you need near perfect seals, the ones that I have are not good candidates.
McMark |
Feb 15 2005, 01:46 PM
I'd love to see pictures Doug.
Doug Leggins |
Feb 16 2005, 12:21 PM
Mark and Bruce -here are the seals that I have. The seal that is used with the screen guard is in fairly good shape. It should work well for a mold pattern. The other seal for use without a screen guard may not be good enough. THis one has some deformation in one area due to improper instalation or storage. The material is all there it is just out of shape. Two corners have defects too but the corners could possible be repaired good enough to be useable as a pattern. Let me know if you can use them.
Doug Leggins |
Feb 16 2005, 12:22 PM
close up pic
Doug Leggins |
bottom sides
GWN7 |
Feb 16 2005, 07:11 PM
Those look good Doug.
The distorted piece can be removed by making two molds and subing in a good corner for the bad one in the second mold. Those are the late model ones? |
Doug Leggins |
Feb 16 2005, 08:21 PM
The seal with the white paint on it came out of a 73 - non screen guard style. The other seal came out of a 74 and had a screen guard.
I'll send them both to you. The non screen style may not work. Anyone else have one they can provide? |
GWN7 |
Feb 17 2005, 03:23 AM
I'll work on those. I don't know what shape the one off the 72 parts car is in and as it and all my other parts are buried under 6' of ice/snow I won't be able to access the parts shed for another month or two.
Thanks Doug |
Lo-Fi Version | Time is now: 20th May 2024 - 12:20 PM |
