911 struts to borrow?? Need to test fit parts ...., 12.19" Wilwood rotors w/alum hat... |
ppickerell |
Feb 17 2005, 09:11 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Mike,
I have a 911 front end assembly from a late 70's early 80's car that you can borrow if needed. |
fiid |
Feb 17 2005, 09:51 PM
WTF? You think you can post something like that without an explanation..? Did you photoshop that? |
Aaron Cox |
Feb 17 2005, 11:32 PM
seen them on a honduh |
Mueller |
Feb 18 2005, 12:34 AM
you've never seen these?? scalloped rotor, 12.19 dia X .81 thick, only 5.9 pounds (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Jeroen |
Feb 18 2005, 05:58 AM
Tim, what's the deal with the 944turbo rotors on a 911
Care to share some details? |
TimT |
Feb 18 2005, 07:06 AM
Jeroen, I have this brake set up on my 911. With larger diameter calipers you sometimes have to space the whole hub out. I have about a .25" spacers on the spindle. Some large diameter rotors may work depending on how they are backspaced from the hub
914Timo |
Feb 18 2005, 08:55 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
I have the same ยด86 951 rotors, but I use them with Boxter monoblocks. Everything seems to fit ok, but I have not yet tested them in practice. TimT, what kind of rear brakes do you have ?? Do you use MB 23mm MC ?? |
914Timo |
Feb 18 2005, 08:59 AM
Shhhhhh.......T !!!! Hard to believe, but if you say so I have to believe it. I have not yet tested that. Good to know I have to get some spacers. Thanks !! |
fiid |
Feb 18 2005, 11:04 AM
wow... that's freakin cool. I suppose they are really light and since surface area isn't helping - will brake just as well an cool a lot better. I bet the constant leading edges are a bit tough on pads though....? |
Lo-Fi Version | Time is now: 8th June 2024 - 06:07 AM |
