Looking for help - ideas for making windshield washers work, -- since i have 5 lug now, put in a space saver tire and cant use tire for pressure on old system |
DRPHIL914 |
Jun 9 2015, 07:58 AM
so what are myoptions? any one ever use some type of pressurized bottle of air, similar to using the tire? or just put a pump in place? how hard is that upgrade?
Steve |
Jun 9 2015, 08:06 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
so what are myoptions? any one ever use some type of pressurized bottle of air, similar to using the tire? or just put a pump in place? how hard is that upgrade? Just install an electric pump Check the classic thread forum for instructions. I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. |
ConeDodger |
Jun 9 2015, 08:16 AM
Apex killer! Group: Members Posts: 23,585 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Sir Andy pioneered a method using 944 parts if I recall.
I believe it's in the Lapuwalli Classics |
BillC |
Jun 9 2015, 08:46 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Steve |
Jun 9 2015, 09:03 AM
I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. Do you have a part number for that wiper switch? I'd like to do this also, but not sure which one to order. Thanks! http://www.pelicanparts.com/techarticles/9...tric_washer.htm |
BillC |
Jun 9 2015, 10:42 AM
I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. Do you have a part number for that wiper switch? I'd like to do this also, but not sure which one to order. Thanks! http://www.pelicanparts.com/techarticles/9...tric_washer.htm Either Pelican's article is out-of-date (or has bad part numbers), or Pelican doesn't carry that switch anymore. Doing a search for that part number brings up listings for lightweight flywheels. |
Steve |
Jun 9 2015, 11:51 AM
I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. Do you have a part number for that wiper switch? I'd like to do this also, but not sure which one to order. Thanks! http://www.pelicanparts.com/techarticles/9...tric_washer.htm Either Pelican's article is out-of-date (or has bad part numbers), or Pelican doesn't carry that switch anymore. Doing a search for that part number brings up listings for lightweight flywheels. Give them a call. There customer service is awesome!!! |
jim_hoyland |
Jun 9 2015, 12:01 PM
Get that VIN ? Group: Members Posts: 9,289 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
so what are myoptions? any one ever use some type of pressurized bottle of air, similar to using the tire? or just put a pump in place? how hard is that upgrade? Just install an electric pump Check the classic thread forum for instructions. I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. (IMG:style_emoticons/default/agree.gif) The most efficient way to go. You won't need those check valves with the electric pump ( one less thing to maintain ) |
billh1963 |
Jun 9 2015, 12:46 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Google search also locates the same part in the ’74 Karmann Ghia, and ’74 to ’79 Beetle
billh1963 |
Jun 9 2015, 12:48 PM
billh1963 |
Jun 9 2015, 12:52 PM
DRPHIL914 |
Jun 9 2015, 04:02 PM
Thanks! |
DBCooper |
Jun 9 2015, 05:18 PM
Interesting. What do you use to inflate the space saver?
Jun 9 2015, 05:28 PM
so what are myoptions? any one ever use some type of pressurized bottle of air, similar to using the tire? or just put a pump in place? how hard is that upgrade? Yes ... It's in our own tech article section right here: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) |
Valy |
Jun 9 2015, 06:15 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
so what are myoptions? any one ever use some type of pressurized bottle of air, similar to using the tire? or just put a pump in place? how hard is that upgrade? Just install an electric pump Check the classic thread forum for instructions. I installed a 924 wiper switch, which has an extra switch for the pump. Do a search, lots of other options for the switch. (IMG:style_emoticons/default/agree.gif) http://www.914world.com/bbs2/index.php?showtopic=117014 |
Lo-Fi Version | Time is now: 14th May 2024 - 01:19 PM |
