Upper Dash Pad Question, What have people used as padding under new vinyl? |
ehokana |
Jul 28 2015, 02:28 AM
Member Group: Members Posts: 99 Joined: 11-August 13 From: SoCal Member No.: 16,237 Region Association: None |
Hey guys
I have started working on getting my car back together and decided to get the dash reupholstered to match the rest of the interior. Anyway, I pulled the vinyl on the upper dash off so that it could be matching as well, and some of the foam-type padding came up and tore- not exactly unexpected for 40 year old foam. I spent tonight cleaning the glue off of the upper dash (what a job that was) so that I could glue the new piece down once I get it back from the upholstery shop. So, to my question, what have people used to replace the foam padding under the vinyl when you replaced the upper dash pad? I thought about just gluing the new piece of vinyl directly without any padding to back it (because vinyl now is significantly thicker than what was used on the upper dash originally) but I'm afraid that every little bump on the dash will eventually show as a dimple on the vinyl. Does anyone have suggestions or something that has worked for them? |
wes |
Jul 28 2015, 09:12 AM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I bought my upper dash vinyl from 914Rubber and the foam pad came with it, Im installing it today
LukeD |
Jul 28 2015, 10:54 AM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
Tips on installing with the windshield and dash in the car? I have the 914rubber kit and the foam is not pre-cut and I'm not sure it can be installed without removing something
DRPHIL914 |
Jul 28 2015, 12:36 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i did this a few years ago and i got the foam from A.A. i dont remember having to do any kind of trimming at all.
76-914 |
Jul 28 2015, 01:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I just did this last month. Look back a few weeks in my build thread. Pretty sure I covered most everything. Look at the "73 restoration Suby Conversion" thread on today's pg 1. BTW, you can use your old piece of vinyl as a nominal guide.
MoveQik |
Jul 28 2015, 05:20 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I just did mine. Admittedly, I had the benefit of the windshield being out of the car which made for a very easy job. I used 1/8" open cell foam. I made sure the dash was smooth and then used spray adhesive to put it on the dash. Then did the same to attach the vinyl on top of the foam. Turned out totally bump free even with some custom "body work" filling in the defrost vents.
Attached thumbnail(s) |
76-914 |
Jul 28 2015, 07:04 PM
Jesus Mike, You don't have an ashtray!! Where do you put your roaches? (IMG:style_emoticons/default/confused24.gif)
MoveQik |
Jul 28 2015, 10:27 PM
Jesus Mike, You don't have an ashtray!! Where do you put your roaches? (IMG:style_emoticons/default/confused24.gif) I had to switch to edibles. (IMG:style_emoticons/default/chowtime.gif) |
ehokana |
Jul 29 2015, 03:33 AM
Thanks for the help guys! I talked to the shop owner of the upholstery place that is doing the dash and he told me that he'll cut a piece of foam to use with the vinyl piece. I don't know why I didn't think of that solution earlier...
MoveQik- that looks fantastic! I have the windshield out of my car currently so I should have a little bit easier of a time also |
Lo-Fi Version | Time is now: 6th May 2024 - 11:42 AM |
