car is back, needs timing adjusted and dwell |
bd1308 |
Feb 28 2005, 11:39 AM
well i got the car back...looks awesome! Need to change points, adjust dwell, adjust timing(by myself....so that really goign to be difficult)...anybody have a good dizzy (for a 2.0) and/or maybe a compufire/pertronix?
scotty914 |
Feb 28 2005, 03:07 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
(IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif)
my second one ever, through another set of points in it, set you dwell tune it and go drive it, worry about another dizzy later |
bd1308 |
Feb 28 2005, 03:10 PM
before
bd1308 |
after
Attached File(s) car2.jpe ( 61.97k ) Number of downloads: 0 |
bd1308 |
Feb 28 2005, 03:11 PM
i actually went and bought my FLAPS's stock of points (2) and John gave me a new tube of BOSCH grease, so i should be set to go |
scotty914 |
take a pic of the front inside of the trunk
bd1308 |
Feb 28 2005, 03:13 PM
inside trunk...sorta (i was too excited to get good pictures)...dunno why it looks orange though..... :shrugs: i like the riveras much better though.
Attached File(s) car7.jpe ( 59.57k ) Number of downloads: 0 |
Allan |
Feb 28 2005, 03:16 PM
Oh great, the meter latches are upside down and the floor brace upper contour is reversed. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Looks great and damn it was fast.
bd1308 |
Feb 28 2005, 03:18 PM
what are you talking about? |
scotty914 |
Feb 28 2005, 03:22 PM
was this a clip replacement, it looks like it was. i am saying this because of the dents in the wheel wells, but it looks good.
and you know use 914ers, we pick any pic apart |
bd1308 |
Feb 28 2005, 03:24 PM
yeah i got it from a junk car in a local junkyard.....worked well though..very very well. my ()*&(*^ dwell keeps on moving on me. Car popped and pinged all the way to Bowling Green yesterday. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Twystd1 |
Feb 28 2005, 03:33 PM
Does the dwell keep changing or do you mean the timing keeps changing...
If it's dwell. Ya could have loose points, or a smoked dizzy top or bottom shaft bearing or the points plate is moving around off axis... Anyway.. Dats what I thunk.... Twystd1 (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
TravisNeff |
Feb 28 2005, 03:35 PM
Good to see that you got it all fixed up, looks sharp!
TravisNeff |
Feb 28 2005, 03:38 PM
As your points wear, the dwell constantly changes. Which in turn changes your timing. that is why you set your dwell first, then timing
bd1308 |
Feb 28 2005, 03:42 PM
right, well how often do you change points....seems like i'm doing it every time i get my oil changed. i adjust them weekly, just about. This time I adjusted it when i got the car (saturday)and its off right now(monday)
Allan |
Feb 28 2005, 03:44 PM
Just messing with ya. Looks really good. Get it tweeked and drive. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
TravisNeff |
Feb 28 2005, 03:54 PM
Seems like I am futzing with mine quite a bit too. I think at 3 or 6k intervals is the specified maintenance points. If you are goofing around with it that much, switch to an electronic gizmo and dump the points. Your dwell will not change and your timing should stay on the mark for a long, long time.
If you have a worn distributor points cam, I think the optical (crane)replacement alleviates that. my dwell meter dropped on the floor and no worky no mo', I guess that is a good enough excuse to go electronic rather than buying another meter. |
scotty914 |
Feb 28 2005, 03:58 PM
i have never checked or adjusted my points... where do i hook up the dwell meter
bd1308 |
Feb 28 2005, 04:06 PM
HAHAHAHAHAH FUNNY....not. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) i think one goes on your finger, the other goes on the coil pack and you stick your tongue on the 12V+
kafermeister |
Feb 28 2005, 07:30 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
Looks good Britt. That didn't take long. What....2 weeks or so?
(IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) Rick |
Lo-Fi Version | Time is now: 17th May 2024 - 02:39 PM |
