Visor Rebuild service GB Need 10 sets to do at $115, So who needs a set rebuilt LAST DAY TODAY !!! |
Mikey914 |
Aug 10 2015, 08:30 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looking at another run of visors to recover $110 a set in vinyl naked or with flap and pocket, but need 12 sets to do this. Many happy customers, and better than $300+ for a decent set of visors.
Who's interested? You will need to send in a stripped core (we can strip for $25 more), and we will recover. Shipping is not included in the cost. -Mark Attached image(s) |
AZ914 |
Nov 11 2015, 10:11 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
QUESTION:
Anyone having an issue installing these? I cannot get the passenger visor to stay in the 'up' position, either forward or backwards. It will slowly sag down. I've tried to snug the screws up to the pins as hard as possible, I've tried to shim the pins with some electrical tape thinking the metal bracket is too loose, etc. No luck. The drivers side stays up 'pretty-well' but can start sagging when hitting bumps. Ended up breaking one of the pins off, so now I'm SOL. Anyone else have this issue or a suggestion? |
Mikey914 |
Nov 11 2015, 11:03 PM
QUESTION: Anyone having an issue installing these? I cannot get the passenger visor to stay in the 'up' position, either forward or backwards. It will slowly sag down. I've tried to snug the screws up to the pins as hard as possible, I've tried to shim the pins with some electrical tape thinking the metal bracket is too loose, etc. No luck. The drivers side stays up 'pretty-well' but can start sagging when hitting bumps. Ended up breaking one of the pins off, so now I'm SOL. Anyone else have this issue or a suggestion? I'm betting the screws were not cut quite short enough. You can file off about 1/16" I do have the old ones I can return but they are not a pretty. Drop me the name in a PM I'll get you a new visor clip. Mark |
AZ914 |
Nov 12 2015, 07:14 AM
QUESTION: Anyone having an issue installing these? I cannot get the passenger visor to stay in the 'up' position, either forward or backwards. It will slowly sag down. I've tried to snug the screws up to the pins as hard as possible, I've tried to shim the pins with some electrical tape thinking the metal bracket is too loose, etc. No luck. The drivers side stays up 'pretty-well' but can start sagging when hitting bumps. Ended up breaking one of the pins off, so now I'm SOL. Anyone else have this issue or a suggestion? I'm betting the screws were not cut quite short enough. You can file off about 1/16" I do have the old ones I can return but they are not a pretty. Drop me the name in a PM I'll get you a new visor clip. Mark Ah.. ok, that makes sense. If the screws are a bit too long on mine, they won't allow the ring to snug up. I will give that a try. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:08 PM |
