drain tube in front trunk |
wilchek |
Mar 5 2005, 04:49 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Does anyone know which hole the drain tube should be in, in the front trunk. Is it the hole under the tire or the one closest to the fire wall.
bd1308 |
Mar 5 2005, 05:41 PM
i actually am unfamiliar with this. I was unaware that the front trunk HAD a drain tube. Are you talking about the one that is for the fresh air box? Please post some pictures
(IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) |
mattillac |
Mar 5 2005, 06:03 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
drain tube for what? fresh air box? gas tank overflow? headlight buckets? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mar 5 2005, 07:17 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you have a hole under your tire ??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif) |
mattillac |
Mar 5 2005, 07:19 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
smrz914 |
Mar 5 2005, 07:41 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
could it be the hose that connects to the spare tire valve to presureize the windshield washer fluid tank?
Doug Leggins |
Mar 5 2005, 07:52 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
Here's a pic that should help. I think that wilchek is asking about 1 & 2.
I'm not sure what goes in 1 & 2. Or 3 - 6 either. I am going to expand on Wilchek's question. Anyone know what goes in each 1-6? Wilchek - Are you referring to a drain tube that is several inches long and just hangs down from the front trunk? I've seen a pic of a car with front drains but can't remember where. Anyone else seen the drain tubes? Got pics? Attached image(s) |
wilchek |
Mar 5 2005, 08:04 PM
"This Thread is Worthless without PIcs" OK I guess I deserved that, here are the pics. It is simplly the drain tube that vents any thing from the bottom of the trunk. If you look under some cars in the front you will see the hose piece hanging down. So, does anyone know where it should go, in hole A or B. One should be a plug like the others and one should be the drain tube ($5.00 btw) in the second pic. Hopes this clarifies things
Mar 5 2005, 08:07 PM
aha, now we're talking ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) mine was excatly like yours, the little plugs/drains in the 4 front holes, 2 rear holes empty ... wonder what they were used for ... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Doug Leggins |
Mar 5 2005, 08:12 PM
Do you have a part number for that drain tube? Where did you buy it?
I would like to add that finishing touch to my car. |
Mar 5 2005, 08:17 PM
actually, them drain holes work *much* *better* *without* the rubber drain plugs installed ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
wilchek |
Mar 5 2005, 08:26 PM
I was thinking about leaving it out, But I am afraid that more water would be pushed up it as the hole is fairly large. I figured for 5 bucks replace it and give the truck some proper venting. I know my Honda has the same system in the trunk and it works fine.
I am sure GPR can get it for you. Should be less than 5 bucks. Here is the part bag it came in. From the part # I would say it is the same part used on 911 so it should be easy enough to get. I am getting one of the plugs missing from a salvage yard as I order a part and asked to throw one in. I assume the plug can be bought new also. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 01:06 PM |
