'73 1.7 air filter?, any sources for correct new ones? |
BillC |
Oct 19 2015, 06:34 PM
Senior Member Group: Members Posts: 544 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Does anyone have a source for new air filters that will fit a '73 1.7 914? I've been searching, but the only place I can find that lists that application is AA. Unfortunately, the ones they sell aren't an exact fit -- they are the same outside diameter and same height, but the inside diameter is much larger and won't seal properly inside the air filter housing. I could make an adapter out of sheet aluminum, but would rather have the correct fitment instead.
BTW, I called AA and asked them about the filters they sell not fitting correctly. Their response was basically "we know, but no one has anything better; and we're not going to bother making adapters, either." |
Oct 19 2015, 06:48 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
BillC |
Oct 19 2015, 07:28 PM
Thanks for the link. Unfortunately, it doesn't answer the question. Guess I'm just going to have to make an adapter, to make up for the too-large ID. |
Oct 19 2015, 09:05 PM
I'm in the same boat, and have done some looking around for a filter that is close enough to fit with a little cutting or gasketing.
Below is some info I posted a while back. I still haven't gotten my 1.7 back together far enough to need an air filter, so I haven't actually tried any of these yet. Dimensions: Mann C2180 (OEM, NLA) 124mm ID 207mm OD 82mm tall Champion AF103 (NLA) 125mm ID 205mm OD 82mm tall The K & N E-1040 160mm ID 211mm OD 83mm tall Motorcraft C2OZ9601AR (FA3R) 3.225" tall (81.9mm) 8.313" OD (211.1mm) but can't find an ID for it. I also see slight variations on dimensions depending on where you look. Champion 70567 (1980 Ford F150 w/ 300 I-6) 8.410" OD (213.6mm) 6.630" ID (168.4mm) 3.230" tall (82.0mm) Gary |
Oct 19 2015, 09:06 PM
Post above is the best answer I have seen.
The stock filter is NLA. Reach out to other vendors and you might get lucky and find them on someone shelf, but they have been long gone for a while now. You can make some of the ones listed above work, but nothing is perfect. |
stinkindiesel |
Oct 20 2015, 02:31 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Yep, something close and an adapter is the only thing I've found. I'll keep looking, but I'm not holding out much hope.
At least the Frod filters are cheap! Gary |
Reno914 |
Oct 20 2015, 03:31 PM
Newbie Group: Members Posts: 31 Joined: 18-August 09 From: Reno Member No.: 10,694 Region Association: Northern California |
I saw this post, and I had issues a while back when trying to get a replacement. I ended up taking my filter down to my local NAPA and we matched up the height, and internal diameter to get a replacement that would work.
Ended up with a NAPA GOLD 2110 it has good fitment on the Internal ring, and the height matches well. Might be worth giving a look. Reno |
Kansas 914 |
Oct 20 2015, 05:47 PM
Jamie |
Oct 20 2015, 06:44 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I did some serious searching several years ago for dry air intake replacement filters for my Feb 1973 build 1.7L(all original by the way!) and found a NAPA #2909 filter to be an exact replacement for the original. Don't know if the product number has changed, but there are replacements available. (IMG:style_emoticons/default/aktion035.gif) |
doug_b_928 |
Oct 20 2015, 07:09 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I thought it was NAPA GOLD 2011?? |
913B |
Oct 20 2015, 08:38 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
inquiring minds would like to know (IMG:style_emoticons/default/biggrin.gif) |
BillC |
Oct 21 2015, 07:05 AM
I looked up those NAPA numbers, and it looks like the 2011 is closest, but still not quite right (ID is too big). Also, none of them are as tall as the stock filter, so they may not seal properly against the filter housing lid. Size numbers are below, all taken directly from NAPA's web site.
NAPA 2909 ID: 173mm OD: 233mm Height: 67mm NAPA 2011 ID: 164mm OD: 203mm Height: 76mm NAPA 2110 ID: 127mm OD: 161mm Height: 76mm I saw this post, and I had issues a while back when trying to get a replacement. I ended up taking my filter down to my local NAPA and we matched up the height, and internal diameter to get a replacement that would work. Ended up with a NAPA GOLD 2110 it has good fitment on the Internal ring, and the height matches well. Might be worth giving a look. Reno Did you check the fit on the bottom of the air filter housing? The ones I got from AA fit nicely in the top (like in your pic), but they don't seal in the bottom housing. The bottom housing has a center ring for sealing on the ID of the stock air filter, and then ribs farther out. The ID of the AA filters are too big, and sit on the ribs instead of sealing on the center part of the lower housing. I also pulled both parts of the housing out and tested the height of the AA filter -- since the reinforcement ribs are lower than the sealing ring, the AA filter isn't tall enough to seal at the top. Making an adapter will be pretty simple. Just a flat sheetmetal disc (probably aluminum) with an inside hole to match the stock filter and an OD to match the AA filter. And maybe bend up a couple of tabs on the outside to hold the AA filter in place when installing the lid. |
Reno914 |
Oct 21 2015, 09:42 AM
Reno [/quote] Did you check the fit on the bottom of the air filter housing? The ones I got from AA fit nicely in the top (like in your pic), but they don't seal in the bottom housing. The bottom housing has a center ring for sealing on the ID of the stock air filter, and then ribs farther out. The ID of the AA filters are too big, and sit on the ribs instead of sealing on the center part of the lower housing. I also pulled both parts of the housing out and tested the height of the AA filter -- since the reinforcement ribs are lower than the sealing ring, the AA filter isn't tall enough to seal at the top. Making an adapter will be pretty simple. Just a flat sheetmetal disc (probably aluminum) with an inside hole to match the stock filter and an OD to match the AA filter. And maybe bend up a couple of tabs on the outside to hold the AA filter in place when installing the lid. [/quote] I think I can take a look this evening and and get a picture for you (depends on kids/wife/etc.). When I got the replacement air filter I took the old one down, and the guys at Napa measured the ID and height of the old filter and we worked to find one that would match and fit inside the air box. Reno |
Reno914 |
Oct 21 2015, 09:44 AM
I thought it was NAPA GOLD 2011?? Doug the air filter I have in my car has the number 2110 Reno |
doug_b_928 |
Oct 21 2015, 09:58 AM
Interesting. My car is inoperable but I bought a 2011 and compared it to the existing filter (at least 30 years old) and it was not an exact match, but was thought to be the closest possible. I should have taken a picture but don't think I did and everything is now in storage.
BillC |
Oct 22 2015, 07:34 PM
Just for giggles, I went down to the garage to look at the two filters I got from AA. The first one had no numbers, but had a spot that looked like it might have had numbers at one point. The other one had very faint, hard-to-read markings, but clearly says NAPA Gold 2011. So now we know where their filters actually came from.
913B |
Oct 22 2015, 08:05 PM
what is the consensus, which has a better fit 2011 or 2110 ? (IMG:style_emoticons/default/idea.gif)
stinkindiesel |
Oct 23 2015, 12:50 PM
124mm ID 207mm OD 82mm tall NAPA 2011 ID: 164mm OD: 203mm Height: 76mm NAPA 2110 ID: 127mm OD: 161mm Height: 76mm So the 2011 and 2110 would both need a 6mm (just a hair under 1/4") gasket to seal top and bottom. 2110 has the smaller ID, so is more likely to seal to the flat area of the filter housing. Take some 1/8" gasket material, cut two 6.5" donuts, and place one under and one over the 2110 and you should be close enough to get a good seal. Gary |
Reno914 |
Oct 23 2015, 01:30 PM
[/quote]
Did you check the fit on the bottom of the air filter housing? The ones I got from AA fit nicely in the top (like in your pic), but they don't seal in the bottom housing. The bottom housing has a center ring for sealing on the ID of the stock air filter, and then ribs farther out. The ID of the AA filters are too big, and sit on the ribs instead of sealing on the center part of the lower housing. I also pulled both parts of the housing out and tested the height of the AA filter -- since the reinforcement ribs are lower than the sealing ring, the AA filter isn't tall enough to seal at the top. Making an adapter will be pretty simple. Just a flat sheetmetal disc (probably aluminum) with an inside hole to match the stock filter and an OD to match the AA filter. And maybe bend up a couple of tabs on the outside to hold the AA filter in place when installing the lid. [/quote] here is how the filter fits on the bottom housing. Definitely fits on the flat, and has very little movement side to side against the internal lip on the bottom. I have not tried to see how much space is between the filter and the housing top to bottom. need to figure out how to do that. Reno |
BillC |
Oct 23 2015, 03:19 PM
Definitely fits on the flat, and has very little movement side to side against the internal lip on the bottom. I have not tried to see how much space is between the filter and the housing top to bottom. need to figure out how to do that. Reno When I checked mine, I took the whole filter housing out of the car (top and bottom). I then pulled the old filter, stuck the new filter in and put the top on the bottom. I then just shook the filter assembly up-and-down, and listened to the filter bounce up-and-down in there. Not really a quantitative measurement, but a good indication that the filter wouldn't seal -- if it sealed properly, it wouldn't move inside the housing. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:00 AM |
