I looked up those NAPA numbers, and it looks like the 2011 is closest, but still not quite right (ID is too big). Also, none of them are as tall as the stock filter, so they may not seal properly against the filter housing lid. Size numbers are below, all taken directly from NAPA's web site.
NAPA 2909
OD: 233mm
Height: 67mm
NAPA 2011
OD: 203mm
Height: 76mm
NAPA 2110
OD: 161mm
Height: 76mm
QUOTE(Reno914 @ Oct 20 2015, 05:31 PM)
I saw this post, and I had issues a while back when trying to get a replacement. I ended up taking my filter down to my local NAPA and we matched up the height, and internal diameter to get a replacement that would work.
Ended up with a NAPA GOLD 2110
it has good fitment on the Internal ring, and the height matches well.
Might be worth giving a look.
Click to view attachment Reno
Did you check the fit on the bottom of the air filter housing? The ones I got from AA fit nicely in the top (like in your pic), but they don't seal in the bottom housing. The bottom housing has a center ring for sealing on the ID of the stock air filter, and then ribs farther out. The ID of the AA filters are too big, and sit on the ribs instead of sealing on the center part of the lower housing. I also pulled both parts of the housing out and tested the height of the AA filter -- since the reinforcement ribs are lower than the sealing ring, the AA filter isn't tall enough to seal at the top.
Making an adapter will be pretty simple. Just a flat sheetmetal disc (probably aluminum) with an inside hole to match the stock filter and an OD to match the AA filter. And maybe bend up a couple of tabs on the outside to hold the AA filter in place when installing the lid.
