16 Pages V « < 13 14 15 16 >
> NEW Group Buy 914 Master Cylinders $110 each, GB CLOSES TODAY 11/15/17 The rest will ship by 11/2
Mikey914
post Nov 21 2017, 06:46 PM
Post #281
The rubber man
The easy kit is a modified master cylinder that allows for easier installation with solid connections. Designed to minimize the swearing required with the OEM version.
JoeD
post Dec 1 2017, 10:05 AM
Post #282
Mark, I received my new master cylinder with easy-install option; planning on doing the install this weekend. I haven't seen the install write-up- maybe it's buried in thread and I've missed it. Will it be obvious how the easy-install kit connects to the reservoir lines?
Mikey914
post Dec 1 2017, 10:41 AM
Post #283
The rubber man
It's actually pretty straight forward but I will work on this today so I can send it out to you.
Thanks,
Mark
SKL1
post Dec 1 2017, 04:30 PM
Post #284
Mark- you may want to post that here too. I need a refresher on bench bleeding it.
At least with the easy option I shouldn't have to take out the fuel tank!!
Mikey914
post Dec 1 2017, 05:20 PM
Post #285
The rubber man
We didn't need to either. (IMG:style_emoticons/default/biggrin.gif)
fixer34
post Dec 4 2017, 09:26 PM
Post #286
Yes, some instructions would help. Received mine today with the EZ install kit.
One of the threaded adapters was already installed (nearest the bellows); in a plastic bag there is a hose with plastic webbing on it and a screw clamp. In a smaller bag, another hose with 3 spring clamps and the second adapter. Curious why the second adapter is smaller than the first one.
Let us know what you designed to go where.
Mikey914
post Dec 5 2017, 01:41 AM
Post #287
The rubber man
I've completed the instructions and forwarded to another member to review and add notes. I planned to get some feedback and modify to make a s clear as possible. I'll forward everyone a copy tomorrow.
mark
JoeD
post Dec 5 2017, 06:59 AM
Post #288
QUOTE(Mikey914 @ Dec 5 2017, 02:41 AM) *
mark
Mark, did not get a chance to install the MC this weekend. Hoping to get under the car today but it may be the weekend. Sorry for that.
JoeD
post Dec 6 2017, 05:47 AM
Post #289
Well, the easy option turned out not to be so easy for me, but not Mark's fault.
Got the old MC pulled and removed the reservoir clamp yesterday but ran into a snag. I'm pretty sure someone zip-tied the reservoir lines are together underneath the gas tank, likely just before they separate, connect to the flared tubes and pass through the grommets. Although I have plenty of slack under the reservoir, I can't pull even a half-inch of reservoir line free under the car- impossible to cut and attach the 2 pieces of hose to connect to the MC.
The lines were zip-tied together twice under the reservoir that I can see before they disappear under the tank; I can only assume more of the same under there and that's what's keeping me from being able to pull any line under the car to work with. The lines are definitely hung up on something, somewhere under the tank.
So... going to have to pull the tank anyway, and it certainly didn't save me any swearing. Again, not Mark's problem, but as usual with this car, any "easy" job QUICKLY turns into (IMG:style_emoticons/default/headbang.gif)
drem914
post Dec 19 2017, 11:32 AM
Post #290
QUOTE(JoeD @ Dec 5 2017, 04:59 AM) *
mark
So has there been a final write up done yet and sent out? Just want to make sure I don't mess up anything with the switch over to the new MC. And, since it's up in the air and have to bleed down everything I am installing a new complete set of PMB calipers all around.
Mikey914
post Dec 19 2017, 12:15 PM
Post #291
The rubber man
We have the initial instructions that I've emailed to all that have purchased on Dec 5th. The initial feedback is that the initial set is pretty complete. Bleeding the master cylinder is still an issue. Mostly due to the nature of the layout. I have cautioned to not use power bleeders to bleed the system. This is primarily because I did not test the pressure at which the hoses will leak. The old hoses may not take the load. We have included clamps to help hold the lower section.
These install like the factory master cylinders, but the inlet ports can be mechanicaly secured.
Let me know if you can't find in your inbox.
Mark
restore2seater
post Dec 19 2017, 11:56 PM
Post #292
Future 914 copilot.
Mark,
This was in an email sent to me on Dec. 5th.
"We are compiling our instruction sheet for this part. It is a relatively straight forward process, The big issue was the insertion of the tubes with the rubber grommets. These are particularly troublesome. This kit allows for a much easier installation of the reservoir lines. You will still need to bleed the system and insure that the pedal pin is correctly inserted into the master cylinder.
If you have any tips or tricks you would like us to include we would look forward to your input.
Thanks again,
Mark Whitesell"
Haven't received any other email about instructions since then.
Mikey914
post Dec 20 2017, 01:19 AM
Post #293
The rubber man
Just sent out. Check your email should be there.
Mark
restore2seater
post Dec 20 2017, 09:29 AM
Post #294
Future 914 copilot.
Got it. Pretty simple. Just wanted to make sure there wasn't something out of the ordinary I didn't know of. Customer service second to none. (IMG:style_emoticons/default/first.gif)
Thanks Mark.
post Dec 20 2017, 10:35 AM
Post #295
Hey guys, if you haven't bench bled a master cylinder there are lots and lots of videos on youtube on how to bench bleed brake master cylinders. (IMG:style_emoticons/default/beerchug.gif)
drem914
post Dec 20 2017, 11:33 AM
Post #296
QUOTE(Mikey914 @ Dec 19 2017, 11:19 PM) *
Mark
Got it. Thanks,
Calwaterbear
post Jan 3 2018, 12:04 PM
Post #297
QUOTE(drem914 @ Dec 20 2017, 09:33 AM) *
Mark
Got it. Thanks,
Mark,
Can i get a copy of the instructions, just now getting around to installing
thanks
Mikey914
post Jan 3 2018, 11:07 PM
Post #298
The rubber man
QUOTE(Calwaterbear @ Jan 3 2018, 10:04 AM) *
Mark
Got it. Thanks,
Mark,
thanks
Drop me your email. I can resend.
Mark
KELTY360
post Mar 3 2018, 08:38 PM
Post #299
914 Neferati
Has anybody installed the MC using the quick connect kit? Do you have to cut off the flares from the resevoir lines?
PanelBilly
post Mar 3 2018, 08:48 PM
Post #300
I bought one but it’s still in my sock drawer
- Lo-Fi Version Time is now: 3rd November 2026 - 07:25 AM
