Cell phone / Smartphone mount for Porsche 914, NLA - New design coming |
johannes |
Oct 25 2015, 04:46 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE
https://www.youtube.com/watch?v=yDaeY1dAp0M I just finished and tested the first prototype of the 3D printed cell phone / smartphone mount. The mount replaces the ashtray. This is available as a kit. You will have to order the 3D parts directly from the printer. The 3D printing is made with Polyamide. Its a white, very fine, granular powder. The result is a strong, somewhat flexible material that can take impacts and resist pressure while being bent. The surface has a sandy, granular look, and is slightly porous. The material can be painted. To complete the kit you will also have to source or order 4x M4x12 screws and nuts 1x M4x15 screw 2x 5x70mm rubberbands 2x small pieces of 10x3mm rubber windows seal (see ordering post below) - Fits most phones from the small I-Phone to the large Galaxy from 6 to 8 cm wide (2.3/8 to 3.1/4) THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE ... |
76-914 |
Nov 23 2015, 10:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, what am I missing? The grip range is too large for my Iphone which is ~58mm. Do I need my phone in some case to fit? 2nd, it's floppy and I dont want to over tighten that little bolt. Not sure wh it has mch threads eith. Seems like the long one would be a tapered screw like a sheet rock screw. (IMG:style_emoticons/default/confused24.gif) Is it just me???????
johannes |
Nov 24 2015, 03:17 AM
OK, what am I missing? The grip range is too large for my Iphone which is ~58mm. Do I need my phone in some case to fit? 2nd, it's floppy and I dont want to over tighten that little bolt. Not sure wh it has mch threads eith. Seems like the long one would be a tapered screw like a sheet rock screw. (IMG:style_emoticons/default/confused24.gif) Is it just me??????? The phone support was designed for minimum 60mm so you are a bit under. One of the clamps is free and the other has to be ajusted and tightened. You can put your phone in a case, this would be the easiest way to fix the issue. The clamps have a rake and if your phone is very thin, you can glue a 3 to 5mm rubber or foam on the surface that will receive the back of your phone. THis will push the phone towards the clamps. You can shorten the main part about 1mm each side with a file and gain 2mm clamp travel If the ball join with main frame assembly is floppy you better disassemble and put some glue on the surface before re assembling. This is not intended to be disassembled in the future. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:34 PM |
