Cell phone / Smartphone mount for Porsche 914, NLA - New design coming |
johannes |
Oct 25 2015, 04:46 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE
https://www.youtube.com/watch?v=yDaeY1dAp0M I just finished and tested the first prototype of the 3D printed cell phone / smartphone mount. The mount replaces the ashtray. This is available as a kit. You will have to order the 3D parts directly from the printer. The 3D printing is made with Polyamide. Its a white, very fine, granular powder. The result is a strong, somewhat flexible material that can take impacts and resist pressure while being bent. The surface has a sandy, granular look, and is slightly porous. The material can be painted. To complete the kit you will also have to source or order 4x M4x12 screws and nuts 1x M4x15 screw 2x 5x70mm rubberbands 2x small pieces of 10x3mm rubber windows seal (see ordering post below) - Fits most phones from the small I-Phone to the large Galaxy from 6 to 8 cm wide (2.3/8 to 3.1/4) THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE THIS ITEM IS NO MORE AVAILABLE. NEW DESIGN IS AVAILABLE HERE ... |
76-914 |
Nov 25 2015, 05:27 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Made those two mods and luv it (IMG:style_emoticons/default/wub.gif) Also hit it with some duplicolor vinyl spray paint.
If you look closely you can see the head 0f the #8 1" sheetrock screw and the bead of JB Weld around the stem base. Solid as a rock now. Also added a thin strip of foam on one side. The texture of the material blends well with the OEM look. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:14 PM |
