Which conversion is harder to accomplish/in a 914, A. porsche 2.7 or 3.0 engine or B. the suby 3.3/Turbo |
patssle |
Oct 31 2015, 10:08 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Apologies for the hijack but...I took a look at your conversion blog and was wondering about your comment re: stainless braided oil line “I won’t use these again" Why’s that? Thanks They are not user-friendly. Tough to get the hose ends screwed into the hose and also can scrape your fingers when cutting if not careful. They also don't bend barely at all. Also expensive. There are some Push-Loc hoses/fittings I would probably try if I did another conversion. |
patssle |
Oct 31 2015, 10:11 AM
Hey,..Thanks Patssle,..That is great info,..would love to hear rhat engine,..??? LOL Frank https://www.youtube.com/watch?v=XIIH5ZSfbTE |
flmont |
Oct 31 2015, 09:59 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Damn,that is a sweet sound.....
MoveQik |
Nov 1 2015, 01:55 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I'm getting started on Porsche 2.7L conversion. I'll detail the process (although this has already been done) as much to keep me on track as to help others. What I do know is involved are the following: 914/6 oil tank and fittings Early (65-69) 6 bolt flywheel 914/6 motor mount Front oil cooler and associated lines and fittings 914/6 exhaust headers (or very expensive heat exchangers) You will also need to make a decision on the fuel system. I am going to initially use the stock 1974 CIS injection system that came with the engine I bought. I may later switch to Megasquirt injection since I currently have that on my 2056 4. I believe I can keep the cost below $3,000 plus the cost of the engine so a total of about $8,000. I know that a Subi could be done for much less but I like the purity of keeping a Porsche engine. FWIW, I think you will have to be willing to wait....and wait to find the right deal on every part you need if you plan to keep it under $3k. The oil tank and neck are $1k alone. Oil lines, thermostat, fittings, cooler shroud etc will add up WAY faster than you think. I don't know if your list was intended to be all inclusive but there are a gang of parts needed that aren't listed here. Do a search and you should be able to find it...there are a couple of threads that put together a very detailed list of every part that you need to actually get conversion on the road. It is a lot more than an engine mount, headers and oil fittings. |
Nov 1 2015, 06:51 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
A turbo on a 3.3 Subie is a whole 'nother level of complexity. The 3.3 came NA from the factory. Not as bad as you think really. It is just a stretched 2.2Ls so all them piston, rods, etc work. Custom headers and down pipes and your done. (IMG:style_emoticons/default/lol-2.gif) Highly oversimplified Subaru made a twin turbo flat six? What car did that come in, what years? |
Chris H. |
Nov 1 2015, 07:29 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
A turbo on a 3.3 Subie is a whole 'nother level of complexity. The 3.3 came NA from the factory. Not as bad as you think really. It is just a stretched 2.2Ls so all them piston, rods, etc work. Custom headers and down pipes and your done. (IMG:style_emoticons/default/lol-2.gif) Highly oversimplified Subaru made a twin turbo flat six? What car did that come in, what years? I'm not aware of any stock Subaru 6 cylinder turbo engines. I think what they're getting at is that there WAS a 2.2L 4 cylinder turbo, and the 3.3 is just a 2.2 with 2 more cylinders so there are low compression pistons and stuff available stock. You do find some interesting builds when you search for EG33 turbo. A LOT of them have been turbo'd! |
Dtjaden |
Nov 1 2015, 10:49 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
My target cost of $3,000 is of course based on used and bargain parts as well as some fabricated parts. It does not include transforming the car into a full 914-6, just what is necessary to install a 6 cylinder Porsche engine. It also, of course does not include the cost of the engine.
Some example parts costs: Flywheel - $100 used, OEM new under $200 914-6 motor mount - Under $300 new Oil cooler - used Mazda RX7 and oil lines, under $300 Headers - new under $700, muffler used - under $150 CIS fuel pump - OEM $100 Engine oil lines - self made $200 Engine tins - under $300 or $50 if self fabricated Shift linkage - self modified $0 I'm still looking for a decent used oil tank & fittings (PM me if you have one) I'm getting started on Porsche 2.7L conversion. I'll detail the process (although this has already been done) as much to keep me on track as to help others. What I do know is involved are the following: 914/6 oil tank and fittings Early (65-69) 6 bolt flywheel 914/6 motor mount Front oil cooler and associated lines and fittings 914/6 exhaust headers (or very expensive heat exchangers) You will also need to make a decision on the fuel system. I am going to initially use the stock 1974 CIS injection system that came with the engine I bought. I may later switch to Megasquirt injection since I currently have that on my 2056 4. I believe I can keep the cost below $3,000 plus the cost of the engine so a total of about $8,000. I know that a Subi could be done for much less but I like the purity of keeping a Porsche engine. FWIW, I think you will have to be willing to wait....and wait to find the right deal on every part you need if you plan to keep it under $3k. The oil tank and neck are $1k alone. Oil lines, thermostat, fittings, cooler shroud etc will add up WAY faster than you think. I don't know if your list was intended to be all inclusive but there are a gang of parts needed that aren't listed here. Do a search and you should be able to find it...there are a couple of threads that put together a very detailed list of every part that you need to actually get conversion on the road. It is a lot more than an engine mount, headers and oil fittings. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:14 PM |
