Carbed 914 Problems.002 |
microsa |
Mar 10 2005, 06:02 PM
Member Group: Members Posts: 94 Joined: 20-February 03 From: San Antonio, Tx Member No.: 329 |
Well, to coin a well turned phrase from The Grateful Dead, "what a strange
long trip it's been." Well it's gittn' stranger! Late last night I disconnected all the fuel lines and blew them out; free and clear. I next ran a line on the outside of the car from the fuel pump (mounted under the tank, near the rack) all the way down the side of the car (taped) to the engine compartment to the regulator. Real scary looking, but went ahead anyway, worst case would be the car burns to the ground. Problem still there; hit approx 5500 and the engine goes flat. Removed exterior fuel line and reconnected original fuel lines. Semi-fast-forward to this morning. Removed valve covers and check valve clearance, all the intakes were dead on .006 three of the exhaust were a little tight (maybe .007) the fourth was dead on .008. I went ahead and re-adjusted everything to spec. Turned the motor through and double checked everything. Nothing was correct, some way too tight some way to wide! What the heck?!? Adjusted them again, one side at a time and now I can't get them to repeat! I had someone else adjust them, get them dead on and turn the motor though and whamo! (technical term) they will not repeat! I adjusted them again, and sure enough you can turn the motor though and it's changed. What the heck is going on here? Finally got them close, but a little wide and started up the car. Idles great. Bring up the RPM and it pops misses and generally runs like crap. Worse than before this whole saga started. Took both carbs off and completely dis-assembled them. All passages are clear, all gets, screws and pumps clear. Float levels is correct, needle valve and seat, new. Car will now not even get to 2K under a load. I'm thinking saws-all party at this point. Guesses, anyone? Or is my next step to split the cases? Mike Allen San Antonio, TX |
Twystd1 |
Mar 10 2005, 09:37 PM
By chance do you have hydrauilic lifters?
Twystd1 |
Lo-Fi Version | Time is now: 28th May 2024 - 02:57 AM |
