Narrow body rear with 16 x 8'', anyone got pics/info of this mod/ |
porschetub |
Dec 1 2015, 07:42 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Purchased these size wheels new and would be interested in pics or how your stock rear body was done,not keen on going to flares or running monster tyres as I only have a 2.2T going in.
Was thinking that the body will need a little more that the guard inner lip removed/rolled?,can it be dollied out or need to be cut and sectioned? I currently have reasonable space between inner edge and tire with 7 x 16'' on with 205's . Thanks. |
Mueller |
Dec 1 2015, 07:48 PM
On my phone...let's see if this works...
My 1st 914, 16x8 23mm offset ...cut, sectioned and welded. http://www.google.com/search?q=914+flare+m...8g_XkIyyUDrM%3A |
Mueller |
Dec 1 2015, 07:50 PM
225/50s
For a few weeks before I flared the rear I ran the 8" rims up front and the 7's in the back! |
theleschyouknow |
Dec 1 2015, 08:12 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
On my phone...let's see if this works... My 1st 914, 16x8 23mm offset ...cut, sectioned and welded. http://www.google.com/search?q=914+flare+m...8g_XkIyyUDrM%3A cool link. I really like the narrow body cars, often or sometimes like cars with the "gt" flares (I do often like the dedicated racers with the riveted on fg flares) and rarely like the one offs or the rabbit or bmw flares or any of the myriad of other things folks have cut big holes in their fenders to stick on their cars that being said I think these look pretty cool I have no plans to ever flare my car but anybody know anything about these? would like to see what they looked like body color (IMG:style_emoticons/default/beerchug.gif) cjl |
Mueller |
Dec 1 2015, 11:25 PM
If you follow the tread in which that picture is from of my old car, I also posted a pic of another 16x8 with an 55mm or so offset. The fender is clear from the tire but the tire hits the trailing arm and trunk wall.
So I'd say if you notched or made the trailing arm "bent" like a 911 rear arm and added a little mini-tub to the car you could fit an 8" wide rim with a 225 or even a 245 if lucky under stockish fenders. |
bigkensteele |
Dec 1 2015, 11:41 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
JRust |
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I like the 944 offset 16x8's. They have 1/2" more offset to the inside than the 911 part #'s. Work perfect on a 914. I had them on my v8 car before I added flares. These had 225/45/16's for tires. I had my lips rolled as well as just a little bit of pulling for them to work
Chris H. |
Dec 2 2015, 12:16 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
On my phone...let's see if this works... My 1st 914, 16x8 23mm offset ...cut, sectioned and welded. http://www.google.com/search?q=914+flare+m...8g_XkIyyUDrM%3A cool link. I really like the narrow body cars, often or sometimes like cars with the "gt" flares (I do often like the dedicated racers with the riveted on fg flares) and rarely like the one offs or the rabbit or bmw flares or any of the myriad of other things folks have cut big holes in their fenders to stick on their cars that being said I think these look pretty cool I have no plans to ever flare my car but anybody know anything about these? would like to see what they looked like body color (IMG:style_emoticons/default/beerchug.gif) cjl Almost 100% sure that is JP Stein's old car (which he lovingly called "the shitbox" (IMG:style_emoticons/default/biggrin.gif) ) He hand hammered those flares. Before he sold it it was completely changed with a body kit, wider flares, etc. Painted it bright yellow. |
lonewolfe |
Dec 2 2015, 12:37 AM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I like the 944 offset 16x8's. They have 1/2" more offset to the inside than the 911 part #'s. Work perfect on a 914. I had them on my v8 car before I added flares. These had 225/45/16's for tires. I had my lips rolled as well as just a little bit of pulling for them to work What year did the 944's go this offset? I know there was an early and late offset for 944's. |
somd914 |
Dec 2 2015, 04:42 AM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I like the 944 offset 16x8's. They have 1/2" more offset to the inside than the 911 part #'s. Work perfect on a 914. I had them on my v8 car before I added flares. These had 225/45/16's for tires. I had my lips rolled as well as just a little bit of pulling for them to work What year did the 944's go this offset? I know there was an early and late offset for 944's. This chart might help you http://members.rennlist.com/911pcars/wheelwts.html Or this http://p101tv.com/fuchs_wheel_size_decoder.php |
Mueller |
Dec 2 2015, 09:15 AM
I like the 944 offset 16x8's. They have 1/2" more offset to the inside than the 911 part #'s. Work perfect on a 914. I had them on my v8 car before I added flares. These had 225/45/16's for tires. I had my lips rolled as well as just a little bit of pulling for them to work What year did the 944's go this offset? I know there was an early and late offset for 944's. Big bucks for the 16x8 23mm offset rims now, used to be able to find the Phonedials in that size cheap but not any more, figure Fuchs are even more in demand. |
MoveQik |
Dec 2 2015, 09:23 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
944 wheels. 16x8 with 225/50's on the back. The fenders couldn't quite be pulled far enough for them to fit so they were cut and had a little bit of metal added.
Hope that helps! Attached image(s) |
jd74914 |
Dec 2 2015, 11:51 AM
A long time ago someone narrowed their trailing arms to fit wider tires (with positive offset) under there. Unfortunately, the pictures aren't showing up in the thread for me anymore. (IMG:style_emoticons/default/sad.gif)
http://www.914world.com/bbs2/index.php?showtopic=618 |
Mueller |
Dec 2 2015, 11:58 AM
A long time ago someone narrowed their trailing arms to fit wider tires (with positive offset) under there. Unfortunately, the pictures aren't showing up in the thread for me anymore. (IMG:style_emoticons/default/sad.gif) http://www.914world.com/bbs2/index.php?showtopic=618 You can run the same size rim and tire if you have the proper offset rim (read, custom offset) He did that to run factory rims. Neat mod. |
JRust |
Dec 2 2015, 02:38 PM
Yeah 16x8 fuchs are not cheap in either the 944 or the 911. I like the look of the 911 16x8 a little more as the extra 1/2 inch of lip. Give's the dish a little deeper look. Still the 16x8' 944's are awesome. I love the 16" fuchs on 914's anyway. In my mind the 16" fuchs with polished lip & black centers (IMG:style_emoticons/default/drooley.gif) . Best looking wheel on a 914 (IMG:style_emoticons/default/biggrin.gif)
MoveQik |
Dec 2 2015, 05:10 PM
Yeah 16x8 fuchs are not cheap in either the 944 or the 911. I like the look of the 911 16x8 a little more as the extra 1/2 inch of lip. Give's the dish a little deeper look. Still the 16x8' 944's are awesome. I love the 16" fuchs on 914's anyway. In my mind the 16" fuchs with polished lip & black centers (IMG:style_emoticons/default/drooley.gif) . Best looking wheel on a 914 (IMG:style_emoticons/default/biggrin.gif) But what do you know....you drive a Suby! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
TravisNeff |
Dec 2 2015, 05:25 PM
Wills has got a ghetto bootie!
nine9three |
Dec 2 2015, 05:32 PM
Member Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest |
For the life of me I cant figure out why 914 guys want to stagger wheels on a narrow body car. The deeper dish is so marginally different. This certainly makes sense on a 911 because the larger contact patch really matters with all of the weight out back. Regardless, I'm thrilled with the way my 6x16's look.
MoveQik |
Dec 2 2015, 06:30 PM
For the life of me I cant figure out why 914 guys want to stagger wheels on a narrow body car. The deeper dish is so marginally different. This certainly makes sense on a 911 because the larger contact patch really matters with all of the weight out back. Regardless, I'm thrilled with the way my 6x16's look. Because we like it? (IMG:style_emoticons/default/confused24.gif) And we are thrilled that you are thrilled with the way your car looks! (IMG:style_emoticons/default/beerchug.gif) |
Racer |
Dec 2 2015, 08:17 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Purchased these size wheels new and would be interested in pics or how your stock rear body was done,not keen on going to flares or running monster tyres as I only have a 2.2T going in. Was thinking that the body will need a little more that the guard inner lip removed/rolled?,can it be dollied out or need to be cut and sectioned? I currently have reasonable space between inner edge and tire with 7 x 16'' on with 205's . Thanks. I would think an 8" wheel would require a 225 width tire (ie, not stretching a 205 to fit). If you can fit a 225 on your 7, there is no need for an 8.. plus it saves you bodywork tweeks. That said, some neat solutions posted in this thread to make it work. A 2.2t spec motor is what, 125-140ish hp? I'd keep the 205's |
Lo-Fi Version | Time is now: 17th May 2024 - 05:06 PM |
