| nordfisch |
Dec 12 2015, 12:50 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
I once misadjusted a trigger-points-set believing in this would solve the problems of my car... the unit was still functional afterwards, but I didn't believe in it's reliability anymore.
I found this device many years later in my cellar, decided to readjust it and therefore did some re-engineering. The result was a tool you can control and readjust your trigger-points-set with. The trigger-points themselves don't show any wear. But the fibre rubbing blocks are being grinded down when gliding on the distributor-camshaft, especially when this has become rusty or the original small amount of grease has been gone away. You can adjust even heavy worn trigger-points without any electrical function to the original values by using the tool, that simulates the bottom of the distributor-camshaft. The lifetime of the trigger-point-unit can be prolonged about two additive times this way. This new version is designed to work with the new trigger-points-sets with the plastic hoods covering the points, too. The tool has been well approved in four continents now - no reason to change anything on it in the future. You need a lathe to produce the tool by yourself. Registered users will get a figure - free for non-commercial use only - completed with the dimensions, on request. I don't want this figure to be published in a forum anymore. D-Jetronic is my hobby and I have no financial interest, but not everyone has a lathe to produce it by himself, therefore I have some ready-produced tools in stock most of the time. I can ship the tool worldwide for $ 20.-, shipment included. For further information / questions / additions post to this forum or contact me via PM. How to use the tool for adjusting the Trigger-points of the D-Jetronic The model-specific flute (notch) of the tool has to be pushed into the noses of the base-plate of the points-set or the base-plate itself. This flute centers the tool to the same position as it were in the distributor. This allows exact and symmetric adjustment. Because there exist base-plates in three different thicknesses, the matching flute has to be chosen (figure below!): 1 - On the top a flute for Volkswagen, Porsche...? 2 - On the bottom a flute for base-plates-sets with 3 'noses' (Opel, Volvo, Lancia, Fiat, Citroën, Mercedes - R6, BMW, ...?) 3 - On the second position from bottom a flute for Mercedes – V8 The figure below shows the tool in position (points set type '2'). ![]() 1. Adjust space between tool and fibre rubbing blocks to 0.02 in (0,50 mm) in this position by bending the sheets of the anvil-plate with flat-nose pliers, checking with a feeler-gauge. 2. By inserting a feeler-gauge of 0.04 in (1,00 mm) instead you can check the points in fully-opened situation. The points gap will be 0.03 in (0,75 mm) if correctly adjusted. Adjusting the points has to be approved with sense, power and skillfulness. I used flat-nose-pliers and after some trying out got exact adjustments. You have to take care of the following: 1. The tool has to be pushed into the the trigger-unit all the way up to the stop. Some turning the tool and trying again may help, perhaps a little grease will help. The tool has to fit exactly, therefore the tolerance is minimized. 2. The anvil-plate of the points is mounted insulated, therefore may have some tolerance towards the base-plate. After adjusting one side of the trigger-points-pair, you have to control the opposite side. Maybe you have to re-adjust this a couple of times. But: The D-Jetronic is not a direct injection system. You need not try to adjust the points too precisely. Adjustment to 0.02 in is the optimal value cause then all possible tolerances are adjusted to the average. Even new original trigger points have some tolerance, as I found out. Take care the points are absolutely clean, no grease or oil remains between them. Control the distributor-camshaft isn't rusty or worn-out, scratched You essentially have to grease the fibre rubbing blocks by applying a very small amount of points cam grease when re-installing the trigger-point-unit also. You use this tool at your own risk. It has not been approved by the OEM. Using the tool, you accept this term. (Tool Ver 3.1Xen © 10/2014) Norbert Fischer |
| r_towle |
Feb 27 2024, 08:09 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Ok, WTH is this thread?
nordfisch Tool for adjusting the trigger-points of Bosch D-Jetronic Dec 12 2015, 12:50 PM
Jeff Bowlsby Hi Norbert, I would like to order one of these too... Dec 12 2015, 07:51 PM
nordfisch
Hi Norbert, I would like to order one of these to... Dec 13 2015, 06:51 AM
McMark PM me a PayPal address as well. I'll take one... Dec 13 2015, 12:13 PM
Krieger Nice! I'd like one too. Please PM a Paypa... Dec 13 2015, 12:22 PM
jmalone Thanks for doing this. I would like one as well. ... Dec 13 2015, 06:27 PM
Philip W. This is excellent since the original OEM points ar... Dec 14 2015, 07:58 AM
BillC This is a great idea. I would also like to order ... Dec 14 2015, 09:42 AM
nordfisch Hi,
I now shipped all the tools.
Would like to get... Dec 16 2015, 07:17 AM
Philip W.
Hi,
Would like to ge... Dec 16 2015, 07:19 AM
ndfrigi Hi Norbert, do you still have 1 set of this tool? Dec 16 2015, 11:06 AM
pilothyer If you have more, I would love to have one........... Dec 16 2015, 12:16 PM
ssuperflyoldguy I would like one also, I'll send you a request... Dec 23 2015, 11:14 AM
BillC Mine arrived last night, and it's very nice. ... Dec 24 2015, 06:26 AM
liebe Norbert i would also like one too please Dec 24 2015, 06:45 AM
nordfisch Hi,
two users informed me they did not receive the... Jan 13 2016, 01:00 PM
rdauenhauer PM sent Jan 13 2016, 01:05 PM
Old Yella Bet they'll arrive, takes forever from Europe... Jan 13 2016, 05:54 PM
Philip W. Got mine, thank you! Jan 13 2016, 09:33 PM
McMark Got mine awhile back. Took me a minute to remembe... Jan 14 2016, 04:28 AM
saigon71 PM sent to purchase one. Thanks! Jan 14 2016, 07:15 AM
nordfisch Sorry,
I ran out of tools at this time / must hold... Jan 14 2016, 09:09 AM
ndfrigi Hi Norbert,
Finally received mine from the mail. ... Jan 15 2016, 03:15 PM
nordfisch
Hi Norbert,
Finally received mine from the mail.... Jan 15 2016, 05:24 PM
RenoRoger
Hi Norbert,
Finally received mine from the mail... May 9 2016, 02:55 PM
nordfisch
Hello Norbert;
Do you have any trigger point... May 10 2016, 01:27 PM
Kansas 914
Hello Norbert;
Do you have any trigger poin... May 10 2016, 04:20 PM
911rcr Hi Norbert,
Pm sent to order.
Thanks for produci... Jun 18 2016, 05:53 AM
Amphicar770 Are you still offering these for sale? Thanks. Apr 15 2017, 09:43 PM
nordfisch
... Apr 19 2017, 08:50 AM
McMark
... Apr 19 2017, 11:15 AM
[quote name='nordfisch' post='2477237' date='Apr ... Apr 19 2017, 01:54 PM
Calwaterbear
[quote name='nordfisch' post='2477237' date='Apr ... Apr 19 2017, 02:20 PM
Gussoo007 Hi. I would like to buy this tool too please. If y... Jun 1 2018, 05:22 PM
nordfisch PM sent...
Regards
Norbert Jun 2 2018, 01:34 PM
akokarski Hello Norbert,
I would like to purchase the tool ... Nov 4 2018, 06:35 PM
nordfisch
Hello Norbert,
I would like to purchase the tool... Nov 5 2018, 10:40 AM
dknechtly Hi, Are you still making these? I sure would like... Sep 24 2019, 08:45 PM
Jett Norbert, I would like one of the tools as well. p... Sep 24 2019, 09:28 PM
nordfisch Hi,
I still have tools to sell.
>PMs sent... Sep 25 2019, 02:38 AM
thomas@vintagecarleds.com
Hi,
>PMs sent... Sep 25 2019, 08:54 AM
nordfisch PM sent
Regards
Norbert Sep 25 2019, 10:20 AM
Justo Hi Norbert, If you have any of the trigger-points ... Feb 13 2020, 03:25 PM
nordfisch PM sent
Regards
Norbert Feb 13 2020, 03:51 PM
cary Me too ... Feb 13 2020, 03:51 PM
nordfisch
Me too ...
PM sent...
Regards
Norbert Feb 13 2020, 04:02 PM
cary PayPal sent Feb 15 2020, 11:02 AM
Robson51 PM sent
Rob Eiring Feb 15 2020, 07:06 PM
davep Oh sure, may as well keep the D-jet going. Feb 15 2020, 09:54 PM
nordfisch Hi,
I couldn't ship my tool during the last mo... Sep 23 2020, 03:12 PM
IronHillRestorations What is your current price, shipped to US? I... Sep 23 2020, 07:29 PM
yellowporky I would like one also please Sep 23 2020, 07:50 PM
nordfisch Hi,
the freight rates have rised, therefore I need... Sep 24 2020, 07:54 AM
JOEPROPER I'd be interested in one too. Please. Sep 24 2020, 07:56 AM
cary I'm (MiddleMotors) am in for one too ............ Sep 24 2020, 07:59 AM
simonjb I would like to buy one also...Thanks !! Sep 24 2020, 08:12 AM
dghunta Need one too @nordfisch :cheer: Dec 23 2020, 10:12 AM
Rrrockhound Count me in too, please, thanks! Dec 23 2020, 08:04 PM
914sgofast2 If the tools are now again available, I will take ... Dec 23 2020, 08:10 PM
jack20 I would also like to buy one of your tools. Please... Dec 24 2020, 11:47 AM
nordfisch Hi guys,
I have to tell you there have been proble... Feb 28 2021, 10:17 AM
nordfisch Once again...
I just received a message a tool I ... Mar 3 2021, 11:46 AM
NortonMClassics Hi Nordfish,
I would like to buy one of those tool... Aug 8 2021, 01:00 PM
ROSANGELO84 Hello M.R. Nordfish.
I found out your special tool... Feb 27 2024, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th January 2026 - 06:52 PM |
