HELP: Fuel Hard Line and Fittings, Need some direction here... |
Britain Smith |
Mar 15 2005, 01:24 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Ok, so I want to install stainless steel fuel lines in the center tunnel of my turbo type-4 912 project. At each end of the hard line I want to go to braided line with AN fittings, to the fuel pump and tank in the front and to the engine bay in the rear. I planned to run 3/8" pressure line, 5/16" return (can be 3/8" if it needs to be), and AN-6 braided line everywhere else. My issue is the compatibility of all the different fitting options to go from the hard line to the braided lines. I do not want to use any hose clamps or anything and I want it to look nice. I have researched the various AN fittings, pipe fittings, NPT fittings, Swagelok fittings, flare fittings, etc. and I have looked into different types of hard lines. Can someone give me a simple solution to do what I want to do. I know that there are people how have installed hard lines and braided lines in there cars, someone has to have an easy solution.
-Britain (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
ArtechnikA |
Mar 15 2005, 01:30 PM
there are 37-degree (AN) flare fittings with ferrules and B-nuts. i'd try to use those. they'll connect directly to a standard male AN hose end.
you will need to shop-fab the 37-degree flare; IIRC Earl's and the usual race-supply outfitters have the flaring tools. they're not cheap but you could probably resell them when you're done and be out less than if you'd tried to rent one or contract the job. |
Britain Smith |
Mar 15 2005, 01:34 PM
There are two problems with the flared ends in my situation. First, the hard line needs to make a 90 degree bend at the front of the car right where it comes out. Second, I am not sure if the flare fittings will fit through the holes on the firewall of my car. Do you have a diameter of the of a hole needed to fit a 3/8" flare fitting through?
-Britain |
airsix |
Mar 15 2005, 02:30 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Britain, Flare the lines AFTER they are in place. -Ben M. ps - Don't forget to A] put the nut on before flaring, and B] make sure the nut is facing the right direction (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) pps - Regarding the 90 degree bend where the line comes out of the firewall: Don't bend the line - just use a 90 degree fitting. This is how my fuel lines are run. Line comes out of firewall, terminates with a flare-nut into a 90 degree fitting snugged right up against firewall. Another piece of line is attached to the other side of the elbow and runs along the bottom of the firewall. Nothing sticks out - it's all right against the firewall. |
ArtechnikA |
Mar 15 2005, 02:33 PM
...and the ferrule. and thank you for not asking how we learned this ... |
campbellcj |
Mar 16 2005, 08:45 PM
Britain,
Sorry I spaced on replying to your PM on the "other" board. I found the info on the plumbing bits I used for the tunnel section. The hard-line to AN adapters are made by Russell; I suppose Earls, Aeroquip etc. might also make them, but I didn't readily find them at the time. (IMG:http://www.jegs.com/photos/555100552.jpg) These are however made for aluminum tubing and I would be hesitant to use them with steel tubing. They use a ferrule to get a good compression seal but do not require flaring the tube ends. Here is a direct link to the Jegs page that shows 'em. http://www.jegs.com/cgi-bin/ncommerce3/Pro...077&prmenbr=361 Cheers, |
TimT |
Mar 16 2005, 08:49 PM
Why not weld/sweat/braze/silver solder a AN fitting on the end of the SS tubing where it exits the tunnel?
you could actually weld one end on before you even run the lines, leaving yourself the easiest end to do whil under the car (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Series9 |
Mar 16 2005, 09:11 PM
I looked at a lot of options when it came time to do this on my car and eventually came to the conclusion that it would be far easier to run rubber FI line from end to end. I have far fewer fittings that could leak and it was much easier to do. (IMG:http://www.914world.com/bbs2/html/emoticons/hide.gif) |
airsix |
Mar 16 2005, 09:55 PM
Keep it simple. Put a flare nut on the end & flare it with a $6 flare tool. Then just use a brass fitting adaptor to go AN. -Ben M. |
ClayPerrine |
Mar 16 2005, 10:04 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The Great Carnak sees your future....... Barbecued 914...... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) A flexible rubber line in the tunnel with a constantly moving throttle and clutch cable......That is a recipe for a fire. Do it right and you won't burn that beautiful 914 of yours to the ground. Ask Brad what my wife's 914 looked like after the engine fire. (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
Allan |
Mar 16 2005, 10:16 PM
OOH OOH, I just installed SS lines in my car tonight (pics tomorrow). I just threaded the tubing with a 10MM die which gives me automatic barbed fittings. Going 3/8 both ways. Tested it up to 200 lbs., no leaks.
ClayPerrine |
Mar 16 2005, 10:19 PM
I see that you read my tech article... good move. No bad fires for you grasshopper...... (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Make sure you take a movie of your engine firing off for those of us who can't be there. |
Aaron Cox |
Mar 16 2005, 10:21 PM
or 99 bucks southwest airfare..... go to allans on sat, and then go to a huge west coast 914 gathering at the don and glenn swap on sunday.... make a weekend out here with us.... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
ClayPerrine |
Mar 16 2005, 10:25 PM
Is that round trip? For that cost, I may be able to talk the 914 loving wife into going......
Depends on what we have going at the time. Notebook battery is going dead, and I have to go to work tomorrow. Good night alll. (We need a sleeping smiley) |
Allan |
Mar 16 2005, 10:34 PM
Yep, followed your thread. The only problem was with the engine mount installed there is no way to run it continuously. Had to put a junction in.
Series9 |
Mar 16 2005, 10:46 PM
I appreciate your concern and your expertise Clay, but I have taken the necessary precautions by securing the lines carefully away from all moving parts. Besides, a fuel leak in the tunnel is not remotely as dangerous as one in the engine bay (where everyone has rubber lines). |
Lo-Fi Version | Time is now: 19th May 2024 - 01:45 AM |
