> race car pics, fuel cell
9144guy
post Mar 21 2005, 09:08 PM
heres some pics of our shop car that i mostly built metalwize
9144guy
post Mar 21 2005, 09:11 PM
another
9144guy
post Mar 21 2005, 09:13 PM
2 fuel pumps
datapace
post Mar 21 2005, 09:16 PM
Nice, 5 gal?
Any closeups / details on the headlight struts?
-Bryan
Jeroen
post Mar 21 2005, 09:21 PM
Region Association: Europe
more! more! more! more! more! more!
rick 918-S
post Mar 21 2005, 09:23 PM
Hey nice rack! -Celette
QUOTE (Jeroen @ Mar 21 2005, 07:21 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
9144guy
post Mar 21 2005, 09:40 PM
i designed the fuel cell from scratch and welded it has dual pickups one both sides of tank
9144guy
post Mar 21 2005, 09:42 PM
made the peices from 911 old hood shocks and made the clips have not installed the cables yet the will be off a motorcycle
9144guy
post Mar 21 2005, 09:44 PM
hit the wrong button
9144guy
post Mar 21 2005, 09:47 PM
release clips made of 1/4 alum. the tank is ex. 8 gal. 1/8 alum.
9144guy
post Mar 21 2005, 09:50 PM
veiw from the front 1/4 lexan windows weight is 1650lbs
9144guy
post Mar 21 2005, 09:53 PM
installed a batt. box quick release off a bmw,make pluuing engine easier (if needed)
9144guy
post Mar 21 2005, 11:01 PM
pics of car
TC/914
post Mar 22 2005, 08:24 AM
Great work! Why the twin fuel pumps? Do they both run at the same time or are they toggled in case one fails?
I've been planning on something similar, only because I have two rotary pumps and a dual coil mount from a Mazda and thought that they'd look kinda cool together.
Thanks!
TC
9144guy
post Mar 22 2005, 07:09 PM
bottom of engine
john rogers
post Mar 22 2005, 07:30 PM
Where did you get the bladder for the tank? I need to get a new one custom sized.
TimT
post Mar 22 2005, 07:33 PM
retired
Fuel-Safe or ATL will make you a bladder if you supply them with a drawing..
9144guy
post Mar 22 2005, 07:40 PM
has a baffle for the fuel ,no bladder didnt think i needed one we only run, pca events at hallett motor speedway in okla. and some scca events lots of autox
AndrewBlyholder
post Mar 22 2005, 07:46 PM
I not following on the operation of the head light system. The gas strut will raise the headlight. I assume it is held closed by a catch of some sort and you have a cable to release the catch and let the light rise up. What gets the light back down again?
Andrew
9144guy
post Mar 22 2005, 08:09 PM
a old 911 rear deck lid shock ,that dont have enough power to hold up the deck lid. has a 1/4 alum catch that bolts up to old motor holes,witch grabs a fabed piece in bucket area kinda like a ( t ). when the cable is pulled the alum. latch is pulled up allowing the rod going throgh the alum. latch to release, allowing the shock to power the headlight upwards. when you are done you push the headlight down and the latch hooks the rod, preventing the headlight from going upwards. pretty simple
- Lo-Fi Version Time is now: 4th May 2024 - 02:49 PM
