race car pics, fuel cell |
9144guy |
Mar 21 2005, 09:08 PM
Member Group: Members Posts: 253 Joined: 26-February 05 From: tulsa,ok Member No.: 3,672 |
heres some pics of our shop car that i mostly built metalwize
9144guy |
Mar 21 2005, 09:11 PM
another
Attached image(s) |
9144guy |
Mar 21 2005, 09:13 PM
2 fuel pumps
Attached image(s) |
datapace |
Mar 21 2005, 09:16 PM
Member Group: Members Posts: 133 Joined: 19-January 04 From: Atlanta, GA Member No.: 1,579 Region Association: South East States |
Nice, 5 gal?
Any closeups / details on the headlight struts? -Bryan |
Jeroen |
Mar 21 2005, 09:21 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
more! more! more! more! more! more!
rick 918-S |
Mar 21 2005, 09:23 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
9144guy |
Mar 21 2005, 09:40 PM
i designed the fuel cell from scratch and welded it has dual pickups one both sides of tank
Attached image(s) |
9144guy |
Mar 21 2005, 09:42 PM
made the peices from 911 old hood shocks and made the clips have not installed the cables yet the will be off a motorcycle
9144guy |
Mar 21 2005, 09:44 PM
hit the wrong button
Attached image(s) |
9144guy |
Mar 21 2005, 09:47 PM
release clips made of 1/4 alum. the tank is ex. 8 gal. 1/8 alum.
Attached image(s) |
9144guy |
Mar 21 2005, 09:50 PM
veiw from the front 1/4 lexan windows weight is 1650lbs
Attached image(s) |
9144guy |
Mar 21 2005, 09:53 PM
installed a batt. box quick release off a bmw,make pluuing engine easier (if needed)
Attached image(s) |
9144guy |
Mar 21 2005, 11:01 PM
pics of car
Attached image(s) |
TC/914 |
Mar 22 2005, 08:24 AM
Member Group: Members Posts: 203 Joined: 21-October 04 From: Southern MA Member No.: 2,981 |
Great work! Why the twin fuel pumps? Do they both run at the same time or are they toggled in case one fails?
I've been planning on something similar, only because I have two rotary pumps and a dual coil mount from a Mazda and thought that they'd look kinda cool together. Thanks! TC |
9144guy |
Mar 22 2005, 07:09 PM
bottom of engine
Attached image(s) |
john rogers |
Mar 22 2005, 07:30 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Where did you get the bladder for the tank? I need to get a new one custom sized.
TimT |
Mar 22 2005, 07:33 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Fuel-Safe or ATL will make you a bladder if you supply them with a drawing.. |
9144guy |
Mar 22 2005, 07:40 PM
has a baffle for the fuel ,no bladder didnt think i needed one we only run, pca events at hallett motor speedway in okla. and some scca events lots of autox
AndrewBlyholder |
Mar 22 2005, 07:46 PM
Member Group: Members Posts: 109 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
I not following on the operation of the head light system. The gas strut will raise the headlight. I assume it is held closed by a catch of some sort and you have a cable to release the catch and let the light rise up. What gets the light back down again?
Andrew |
9144guy |
Mar 22 2005, 08:09 PM
a old 911 rear deck lid shock ,that dont have enough power to hold up the deck lid. has a 1/4 alum catch that bolts up to old motor holes,witch grabs a fabed piece in bucket area kinda like a ( t ). when the cable is pulled the alum. latch is pulled up allowing the rod going throgh the alum. latch to release, allowing the shock to power the headlight upwards. when you are done you push the headlight down and the latch hooks the rod, preventing the headlight from going upwards. pretty simple
Lo-Fi Version | Time is now: 18th May 2024 - 02:49 AM |
