My First 914 & 2nd Porsche In a Month! |
TM_Corey |
Mar 28 2016, 10:18 PM
Member Group: Members Posts: 231 Joined: 28-March 16 From: Indianapolis Member No.: 19,809 Region Association: Upper MidWest |
My almost two year search for a 911 ended a couple weeks ago with the purchase of my first Porsche, a 2010 Carrera S. But before it did a buddy who knew only that I was looking for a "Porsche" called and said his father in law had one that he had decided to sell. A quick description of the car led me to believe it was probably a 914.
After a month of agonizing of what the car may look like (due to the owners wife being hospitalized shortly after I found out about it) I was finally able to see and utimatley pick up the car today. From what I was told it is a 1974 2.0 that is all original except the radio and the muffler. The owner bought it brand new in 1974 and it hasn't left the Indy area in 42 years. From 1974-1980 it was a year round daily driver. From 1980-1991 it was a "fun car". From 1991 to today it was a work bench in his garage under cover. I could tell that he truly loved this car as it was an emotional day for him today as I loaded it. The car came with 100% documentation, down to every bit of work, oil change, warranty work, manual, window sticker, orignal sales receipt.... The works. The interior is beautiful, the body has its paint surface bubbles and a door has a corner rusted through. The hell hole is rusted through, but remarkably the rest of the car seems very solid. Hoping to have it running soon!!! Attached thumbnail(s) |
TM_Corey |
Apr 18 2016, 07:03 PM
Well it has begun! Decided to go mechanical instead of body work first. I plan to drive it this summer and then start the body work this winter.
It's in the shop, this week will be: New Fuel Lines New Fuel Filter Clean Fuel Tank "New" rebuilt Fuel Pump Clean Injectors New Vacuums lines Replace points with Pertronix New Bosch Blue Coil New Plugs New Plug Wires New Cap & Rotor New Master Cylinder New Brake Hoses Rebuid The Calipers Repack front wheel bearings New Front wheel seals Turn or Replace all 4 Rotors Replace CV axle boots Clean & Repack CV Joints Replace Pushrod Return Tubes Adjust Valves New Valve Cover Gasket Replace Oil Cooler Seals Replace Sump Cover Seal Oil Change & Filter New Battery Repaint Original Wheels New Tires (195/60/15) |
Lo-Fi Version | Time is now: 16th May 2024 - 01:22 PM |
