3.2 motronice ecu mounting locations, how did you guys mount them? Let's see those pix |
914dave |
May 13 2016, 03:08 PM
914 Addict Group: Members Posts: 701 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
For all you 3.2 conversion guys out there. I'm looking for ideas on mounting the ecu and altitude sensor. Under seats, rear trunk I'm open to ideas. I'm assuming that because it's not a sealed unit, that the engine bay is out of the question. I'm having and issue under the seats because I've welded submarine belt bungs to the floor, I've limited my placement options.
Thanks Dave |
Steve |
May 13 2016, 03:12 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I have the Ecu behind the drivers seat. It's held to the backpad with a longer back pad screw. The altitude and DME relay is behind the passenger seat. Didn't have to modify the cables at all.
914dave |
May 13 2016, 03:15 PM
MoveQik |
May 13 2016, 03:58 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Clean. Never in the way and easy access.
Attached thumbnail(s) |
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Dave - I have the interior out of my car. I think I have enough length on the dme harness to run it up the tunnel to the passenger footrest. If that doesn't work, it will probably go in back of the driver seat. I have the fixed passenger seat on my early car.
Steve |
May 13 2016, 07:01 PM
I have the Ecu behind the drivers seat. It's held t the backpad with a longer back pad screw. The altitude and DME relay is behind the passenger seat. Didn't have to modify the cables at all. Steve Are they mounted vertical to the lower firewall? yes, I am just using one back pad screw to hold it in place flat against the backpad. Works great and the cable is just the right length. I can take pictures later tonight. |
buck toenges |
May 13 2016, 07:09 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have mine in the center console behind the gauges. easy to get at the dmv relay. Ran the wiring harness under the center tray and above the tunnel.
Buck |
buck toenges |
sorry, due relay
buck toenges |
May 13 2016, 07:10 PM
DME relay DME relay DME relay.
Cairo94507 |
May 13 2016, 09:11 PM
Michael Group: Members Posts: 9,763 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) Freakin' spell check....
0396 |
May 14 2016, 09:40 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Clean. Never in the way and easy access. Perfect clean location, why to go. (IMG:style_emoticons/default/piratenanner.gif) |
914dave |
May 14 2016, 09:56 AM
Thanks for all the feedback. There are some great ideas. Since I widened my Konig seats , I won't be running a backpad. So I was playing with locations last night and came up with this. I will either make a cover or make a custom center console that covers the ECU. I'll mount the altitude sensor and dme relay behind the pass seat.
TeenerTech |
May 14 2016, 11:20 AM
some mechanic Group: Members Posts: 17 Joined: 21-July 14 From: Grand Rapids, MI Member No.: 17,667 Region Association: North East States |
this is what we have done in the past 3.2 conversions
i personally prefer the under dash mounting because it doesn't interfere with anything. The center seat mounting done here we are going to be building a console for a sub and power window switches so it will be hidden. This is how we rout the wires through the firewall. this is so your not relying on a grommet to keep water out and it makes removing the engine simple, you do not have to remove the entire harness to drop the motor. |
echocanyons |
May 14 2016, 11:42 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
this is what we have done in the past 3.2 conversions i personally prefer the under dash mounting because it doesn't interfere with anything. Please be aware that in doing this the wire harness no longer fits in the stock groove and modifications of carpet and/or omissions of center console are necessary. BTW do you have any more pictures of my car during the time it was spent at Marks shop? I would love to have them. |
May 14 2016, 11:56 AM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I personally prefer the under dash mounting because it doesn't interfere with anything. That's where i mounted my 3.6L brain ... (IMG:style_emoticons/default/smile.gif) |
TeenerTech |
May 14 2016, 11:59 AM
QUOTE BTW do you have any more pictures of my car during the time it was spent at Marks shop? I would love to have them. sure ill let him know tomorrow and we will send you what we have. |
worn |
May 14 2016, 12:11 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I personally prefer the under dash mounting because it doesn't interfere with anything. That's where i mounted my 3.6L brain ... (IMG:style_emoticons/default/smile.gif) Mine is behind the passenger seat. Fuse block from a 911 lives there too for fuel pump and key-on ECU circuit. Figure the passengers are often shorter than drivers. |
May 14 2016, 12:42 PM
I personally prefer the under dash mounting because it doesn't interfere with anything. That's where i mounted my 3.6L brain ... (IMG:style_emoticons/default/smile.gif) If I can get mine to reach, that's where it will go. |
TeenerTech |
May 14 2016, 01:25 PM
QUOTE If I can get mine to reach, that's where it will go. You have to make an extension harness to get it to reach the factory 3.2 harness isn't long enough |
May 14 2016, 01:39 PM
Lo-Fi Version | Time is now: 18th May 2024 - 08:50 PM |
