FS Front and rear Targa Latches, $60 per pair front or rear shipped |
bdstone914 |
May 21 2016, 08:16 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Pictures to follow.
I have a few more pairs of rear targa latches that have new springs and clips and are powder coated. One pair gloss black and others in satin black. $60 a pair shipped. Note that there are two variations of rear latches. The difference is the height and distance between the bumps. The distance between the bumps matches to the rubber block on the top. Not sure of the year break but my 73 VIN 4732915786 has the tall bumps. I suspect that the latches go with the two different tops, early and late. PET shows the tops change in 1973 at VIN 4732926221. They show the same part number for latches for all years. They show two part numbers for the block but the application change is not clear as the 914 563 033 10 is for 974-6/4 and the 914 563 033 19 for 914-1.7/1.8V. Using the wider bump ones on the wrong top allows movement of the top. The other wrong combo does not allow the block to sit flush to the latch. Best to check what is on your car. I have one pair of front latches at this time for $60 a pair shipped. This pair were spray can painted with caliper paint. I have several more pairs that are getting sand blasted and we are going to try to powder coat them. Have to see if the powder coating can be thin enough to not make the moving parts rub. I know we can powder coat the hook parts. One part is zinc and we have had some gassing problem ( not flatulence ) with the zinc causing bubbles in the paint. If it is a problem the latches will be wet painted. Bruce |
Jett |
May 22 2016, 11:27 PM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
The rubber bottom is approximately 1"
Lo-Fi Version | Time is now: 19th May 2024 - 10:42 PM |
