Jeeper John needs a work party! Help get the 6 back on the road, Mostly interior, some mechanical, but mostly together |
Andyrew |
Jun 6 2016, 08:37 PM
Pool? I may just bring Jerika!
Let us know what date works for you, a couple weeks in advance would be great (IMG:style_emoticons/default/smile.gif) |
jeeperjohn56 |
Jun 8 2016, 02:40 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Going to order some seals and other parts before I make a date for work party, will probably be some where towards the end of the month will pick a date later.
housepumpinpc |
Jun 12 2016, 08:03 AM
Give me time... I'll fix it eventually. Group: Members Posts: 31 Joined: 9-May 14 From: Chicago,Illinois Member No.: 17,323 Region Association: Upper MidWest |
Hey guys! Have some window cranks and door latches(interior) if needed. No screws unfortunately. I can't physically help there being in Chicago but reading this, I see the comradery. Just good to read... PM me the address and I'll send em.
green914 |
Jun 12 2016, 09:03 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Mueller |
Jul 1 2016, 04:54 PM
Started to work on the seats.
Cover removed on one of them. Anyone make new seat cushion support boards? I started to make one, but the more I think about it it is the wrong material (pressed board material) |
Mikey914 |
Jul 2 2016, 02:27 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got some boards that we started to make. I will forward to you. PM me your address.
mark |
Mueller |
Jul 2 2016, 02:43 PM
Thanks,
Any recommendations on the thread to use for the above cushion? |
iankarr |
Jul 3 2016, 06:44 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Thanks, Any recommendations on the thread to use for the above cushion? Kite string should work well. It's not exactly the same thickness as OEM, but has the strength needed. https://www.amazon.com/feet-Winding-Nylon-S...ds=Nylon+string Reupholstering the cushion is pretty easy. An air-powered stapler is a big help as you can anchor the material quickly once it's pulled taught. Don't pull too tight though. Flip it over frequently as you go to make sure it's even. The bolsters are more difficult, but not too bad. The hardest part is getting the headrest area properly "filled out." You'll probably need some new foam and poly fill. I used this thread for the process... http://www.914world.com/bbs2/index.php?showtopic=71844 Wish I were closer to help out. This is a great community! |
shoguneagle |
Jul 4 2016, 01:31 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I have some extra parts if they can be used: new 914-6 throttle cable, used clutch cable (in my car for several years but never driven; converted to hydraulic clutch), etc. Just let me know where else I can help.
Steve |
Mueller |
Jul 8 2016, 08:04 PM
Started on the main seat parts. Are the rusted parts shown below available new?
arkitect |
Jul 9 2016, 11:19 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Is there still a need for the work party? Thought that the rear window needed to be redone with a new seal? I'm no expert but willing to help in any way I can.
Dave |
Mueller |
Jul 10 2016, 10:47 AM
Is there still a need for the work party? Thought that the rear window needed to be redone with a new seal? I'm no expert but willing to help in any way I can. Dave Not sure if he has the parts needed yet for that repair. I have one seat fully naked! And yes, I am using the rear decklid of my Volvo 242 as a workbench...nice large flat work surface...and it needs a new paint job anyway (IMG:style_emoticons/default/smile.gif) |
arkitect |
Jul 10 2016, 04:55 PM
I'm glad your able to help John out, can't wait to see the final product for the seats. (IMG:style_emoticons/default/piratenanner.gif)
I reupholstered one seat cushion for my daughter's car, then my puppy got ahold of it and tore it to schreds. The joys of having a new dog. Dave |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:56 AM |
