A Question for our Welder's/Fabricator's |
76-914 |
Jun 8 2016, 01:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've been trying to figure out how you guy's deal with shrinkage. Not for body panels but just general welding. (And no, I did not shrink my car when I installed the Engman Kit) As an example, let's say I'm welding on a 10' piece of pipe that will become a stair rail. Of course it turns 90' on each end and will have flanged ends that screw to the wall. If the 90' elbows are welded on then the length of the rail will shorten "x" inches. Can this be prevented with pre heating. If so, do you apply heat to the entire piece or just where the weld will be? Do you accept that shrinkage will occur and just do not drill any matching holes until after the weld? Is there a formula that adjusts for this shrinkage? Do you bolt it in place then weld to prevent shrinkage? Also, I don't remember this being a problem with gas welding but that was years ago. My imagination or not? TIA, Kent (IMG:style_emoticons/default/beerchug.gif)
Andyrew |
Jun 8 2016, 02:54 PM
Shrinkage isnt typically something that is factored into welding as its pretty small. If that is an issue then most of the time manufacturers use jigs to ensure that the panels remain the size then need to be by affixing the ends of the project.
Warping is however an issue and is rectified by making small tac welds vs long welds. |
mb911 |
Jun 8 2016, 03:09 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Shrinkage isnt typically something that is factored into welding as its pretty small. If that is an issue then most of the time manufacturers use jigs to ensure that the panels remain the size then need to be by affixing the ends of the project. Warping is however an issue and is rectified by making small tac welds vs long welds. Correct and I am a welding instructor and confirm the above statements |
914_teener |
Jun 8 2016, 05:50 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Shrinkage isnt typically something that is factored into welding as its pretty small. If that is an issue then most of the time manufacturers use jigs to ensure that the panels remain the size then need to be by affixing the ends of the project. Warping is however an issue and is rectified by making small tac welds vs long welds. Correct and I am a welding instructor and confirm the above statements Sort of ageee...... During heating and cooling cycles metal goes through a tranny phase.......yes thats right....and we.re not talking bathrooms here. Fixtures don.t address residual stress induced by rapid cooling as you coin ad shrinkage. On my cellphone and train so I could further the explanation if anyone's interested. Love the George post (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:09 PM |
