And so it begins…..again |
Larmo63 |
Jun 17 2016, 06:51 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I bought another '73 2.0 optioned car. It has a really solid tub and is complete. It does run, all I need to do to drive it is install a new master cylinder. Next week the tank gets pulled, MC goes in, five lug gets installed and the madness starts all over again. I really don't need two cars, but sadly, I'm an addict.
Larmo63 |
Aug 19 2016, 02:05 PM
Sorry that it's a Debbie Downer thread, but it seems I take one step forward and two steps back.
I'm just frustrated. I'd like to know if there is some advice on how the horn wire in the column could affect the tachometer, directionals, and gas gauge not working? I was also fiddling with the fog lights and hooked them up properly. The dash light on the switch came on, but no lights. Now the emergency switch doesn't work either. No blown fuses, no hot spots anywhere, no smoking switches or burnt wiring anywhere. I thought tomorrow might be a potential Cars and Coffee appearance. No go. |
r_towle |
Aug 19 2016, 02:41 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Sorry that it's a Debbie Downer thread, but it seems I take one step forward and two steps back. I'm just frustrated. I'd like to know if there is some advice on how the horn wire in the column could affect the tachometer, directionals, and gas gauge not working? I was also fiddling with the fog lights and hooked them up properly. The dash light on the switch came on, but no lights. Now the emergency switch doesn't work either. No blown fuses, no hot spots anywhere, no smoking switches or burnt wiring anywhere. I thought tomorrow might be a potential Cars and Coffee appearance. No go. horn and directional circuits could be shorting out in the column, unplug the plug at the bottom of the column and see if things settle with the gas gauge and the other weird electrical issues. That short harness in the steering wheel may be damaged, but you can set it and pull it out to replace it if required. Drop the fuse box down, see if it was pushed up in place wrong and created a short Check the back of the fuse panel to see if there are any non stock circuits, easy enough to spot. Look for spade connectors touching. Another place for shorts is in the tunnel area in front of the seats where the wiring comes up on top of the tunnel....screws can damage that wiring. Fog lights only come on when headlights are on low beam, and on. There is a trigger coming off the headlight relay to the foglights....gotta see if there is power at the foglight relay under the cowl. Simple cool mod is to get a standard bosch relay at the parts store and wire up the fog lights directly to the switch, not through the headlights. Then you can run with just the fog lights on....or driving lights...whatever they are. Rich |
Lo-Fi Version | Time is now: 16th May 2024 - 05:14 AM |
