Voltage Regulator Working?, I can't tell if my battery is charging |
oakdalecurtis |
Jul 27 2016, 11:42 AM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I installed a new alternator and a new Beru voltage regulator, started up my 76 2.0 and the charging system was sending 18 volts to the battery! Not good. I replaced the new Beru VR with an old Bosch VR, started up the car and now the battery is showing 12.4 volts at the posts, and the voltage doesn't vary a bit with engine speed. I think the 12.4 volts I'm reading at the battery is just the battery's own charge that I'm reading. How can I tell if this old Bosch VR, or any other future replacement VR, is actually charging the battery or not?
87m491 |
Jul 27 2016, 11:58 AM
Member Group: Members Posts: 274 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
I think you answered your own question. New VR was over charging and old VR @ 12.4V isn't really charging. Should be between 13.5-14.
I installed a new alternator and a new Beru voltage regulator, started up my 76 2.0 and the charging system was sending 18 volts to the battery! Not good. I replaced the new Beru VR with an old Bosch VR, started up the car and now the battery is showing 12.4 volts at the posts, and the voltage doesn't vary a bit with engine speed. I think the 12.4 volts I'm reading at the battery is just the battery's own charge that I'm reading. How can I tell if this old Bosch VR, or any other future replacement VR, is actually charging the battery or not? |
oakdalecurtis |
Jul 27 2016, 12:06 PM
I think you answered your own question. New VR was over charging and old VR @ 12.4V isn't really charging. Should be between 13.5-14. I installed a new alternator and a new Beru voltage regulator, started up my 76 2.0 and the charging system was sending 18 volts to the battery! Not good. I replaced the new Beru VR with an old Bosch VR, started up the car and now the battery is showing 12.4 volts at the posts, and the voltage doesn't vary a bit with engine speed. I think the 12.4 volts I'm reading at the battery is just the battery's own charge that I'm reading. How can I tell if this old Bosch VR, or any other future replacement VR, is actually charging the battery or not? Thanks, just wasn't sure. |
porschetub |
Jul 27 2016, 06:30 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I think you answered your own question. New VR was over charging and old VR @ 12.4V isn't really charging. Should be between 13.5-14. I installed a new alternator and a new Beru voltage regulator, started up my 76 2.0 and the charging system was sending 18 volts to the battery! Not good. I replaced the new Beru VR with an old Bosch VR, started up the car and now the battery is showing 12.4 volts at the posts, and the voltage doesn't vary a bit with engine speed. I think the 12.4 volts I'm reading at the battery is just the battery's own charge that I'm reading. How can I tell if this old Bosch VR, or any other future replacement VR, is actually charging the battery or not? Thanks, just wasn't sure. Did you buy this one from Pelican ? I have one also before I started hearing about issues with them (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) |
oakdalecurtis |
Jul 27 2016, 06:47 PM
I think you answered your own question. New VR was over charging and old VR @ 12.4V isn't really charging. Should be between 13.5-14. I installed a new alternator and a new Beru voltage regulator, started up my 76 2.0 and the charging system was sending 18 volts to the battery! Not good. I replaced the new Beru VR with an old Bosch VR, started up the car and now the battery is showing 12.4 volts at the posts, and the voltage doesn't vary a bit with engine speed. I think the 12.4 volts I'm reading at the battery is just the battery's own charge that I'm reading. How can I tell if this old Bosch VR, or any other future replacement VR, is actually charging the battery or not? Thanks, just wasn't sure. Did you buy this one from Pelican ? I have one also before I started hearing about issues with them (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) No, my mechanic got it from a local source. I gave it back to him, no good to me. |
ThePaintedMan |
Jul 28 2016, 08:14 AM
The one I got from AutoZone (had to order) worked fine. I think it was made by Wells. Only like ten bucks.
oakdalecurtis |
Jul 28 2016, 08:57 PM
Lo-Fi Version | Time is now: 20th May 2024 - 06:53 PM |
