914.043.0012, Sorting engine and interior |
gms |
Sep 2 2016, 10:29 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
also finished up the engine wiring harness and starter cable. did some testing on the electrics and everything seems to be in working order.
gms |
Sep 2 2016, 06:07 PM
The car is ready to be started but unfortunately the 914/6 oil hose set I bought is missing the union that connects the oil supply lines. I am going to take it off of my race car tomorrow or Sunday. If you have an extra let me know
gms |
Sep 3 2016, 02:27 PM
gms |
Sep 3 2016, 03:43 PM
sixnotfour |
Sep 4 2016, 05:48 AM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
gms |
Sep 7 2016, 10:10 PM
I have a side shift transaxle in the car so I need a custom rear shift rod that does not hit the exhaust/heat exchangers.
I have set out: Custom rod for sideshift in a 914/6 Early 4 cyl rod Late 4 cyl sideshift rod I used a conduit bender to make the 2 curves in the Early 4 cyl rod |
Sep 8 2016, 04:32 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Glenn - I need to make a side shift rod for my six. I have the same parts as you. Can you explain in more detail what you did. I'm having a hard time following what you did from the pics. It looks like you duplicated what you already had. I'm sure I'm missing something. Thanks.
gms |
Sep 8 2016, 08:57 AM
Glenn - I need to make a side shift rod for my six. I have the same parts as you. Can you explain in more detail what you did. I'm having a hard time following what you did from the pics. It looks like you duplicated what you already had. I'm sure I'm missing something. Thanks. Mark, I spent some time refining the final product so now all I need to do is copy the contours. if you send me an early linkage I will bend it and then you will have a template. |
raynekat |
Sep 9 2016, 12:57 AM
Advanced Member Group: Members Posts: 2,157 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
So is the male-male union the M30 x M30 one at the bottom of the page? |
gms |
Sep 9 2016, 07:59 AM
So is the male-male union the M30 x M30 one at the bottom of the page? I think so...Jeff? |
Sep 9 2016, 08:25 AM
Glenn - I need to make a side shift rod for my six. I have the same parts as you. Can you explain in more detail what you did. I'm having a hard time following what you did from the pics. It looks like you duplicated what you already had. I'm sure I'm missing something. Thanks. Mark, I spent some time refining the final product so now all I need to do is copy the contours. if you send me an early linkage I will bend it and then you will have a template. I appreciate the offer but I'm running out of time befor octeenerfest. I'll work with what I have. |
mb911 |
Sep 9 2016, 08:50 AM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So is the male-male union the M30 x M30 one at the bottom of the page? Yes should be 30mm to 30mm |
Perry Kiehl Clone |
Unregistered |
(IMG:style_emoticons/default/headbang.gif) I cant believe I am just now realizing that GMS is "the" Glenn S. you are one of the pioneers in the 914 hobby! (IMG:style_emoticons/default/beerchug.gif) Scott S Careful he's already got a tough time finding hats (IMG:style_emoticons/default/biggrin.gif) |
gms |
Sep 9 2016, 09:03 AM
(IMG:style_emoticons/default/headbang.gif) I cant believe I am just now realizing that GMS is "the" Glenn S. you are one of the pioneers in the 914 hobby! (IMG:style_emoticons/default/beerchug.gif) Scott S Careful he's already got a tough time finding hats (IMG:style_emoticons/default/biggrin.gif) Perry Kiehl is one of the pioneers in the 914 hobby! his clone...not so much |
Optimusglen |
Sep 9 2016, 09:08 AM
Senior Member Group: Members Posts: 905 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
What a wonderful thread.
gms |
Sep 11 2016, 07:19 PM
I found another great use for my cell phone camera as I was setting timing to change distributors.
gms |
Sep 11 2016, 07:22 PM
this is the slightly different rear view mirror that came on #11 and #12
gms |
Sep 11 2016, 07:26 PM
I was able to get the carbs set well enough to drive it down the street but my STE SK Carburetor Synchrometer broke so i could not get them dial in perfectly.
gms |
Sep 11 2016, 07:32 PM
washed the hood off and took a short drive
Sep 11 2016, 08:19 PM
I'm glad to see another 914 is back on the road. Especially one as interesting as this car. So far, so good.
Lo-Fi Version | Time is now: 5th May 2024 - 09:51 AM |
