Fuel Lines |
Fuel Lines |
sjhenry1075 |
Aug 24 2016, 09:10 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Happy Wednesday everyone. So I have a little bit of a dumb question regarding replacing my fuel lines with SS lines. I purchased lines from Pelican. When I spoke with the salesperson he informed me that he would be including everything I needed in the kit. My question is, I received two sizes and types of hose along with the SS lines; which of these goes where? I have braided hose and regular hose. I appreciate any information you can provide. Again, I apologize if this is a dumb question.
sjhenry1075 |
Aug 29 2016, 06:29 AM
Thank you both. I do have to admit that everyone has been very helpful; I just like to warn people in advance of my lack of knowledge.
So Last night I wanted to remove the lines so I could drain the tank. I reached into the access hole and there wasn't much slack on the lines so I gave them a little tug; both lines broke in half in my hand! Thank goodness I'm replacing them, that could have been disastrous! |
Spoke |
Aug 29 2016, 08:21 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I reached into the access hole and there wasn't much slack on the lines... I looped the hoses so the hoses can be connected with the tank out of the cavity. There's already 15-20 feet of hoses and pipes between the tank and the engine. A couple more feet of hose won't make a difference. |
Bartlett 914 |
Aug 29 2016, 09:08 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I reached into the access hole and there wasn't much slack on the lines... I looped the hoses so the hoses can be connected with the tank out of the cavity. There's already 15-20 feet of hoses and pipes between the tank and the engine. A couple more feet of hose won't make a difference. While this works it is also not too difficult keeping the hoses short and accessing them through the large hole underneath. Before installing the tank, connect the lines and secure them to the lines coming from the tunnel. Have the hoses exit the hole and install the tank. It is not too hard to connect the hoses to the tank at that time. This saves the risk of a pinched line. But long lines work also...... |
Lo-Fi Version | Time is now: 19th May 2024 - 01:39 PM |
