Tons of parts |
Tons of parts |
Tbone425 |
Aug 27 2016, 09:38 PM
Newbie Group: Members Posts: 43 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Southwest Region |
Pics can be found here..(same Username)
http://forums.pelicanparts.com/porsche-914...tml#post9258254 Think I have everything I need, now I’m clearing out the rest of the parts I have collected as part of my project. Prices are plus shipping unless noted as “shipped”. Add PP fees if sending not as a friend. Let me know if there is anything pictured that you need but is not listed. I apologize to those who asked for some of these things, I just had to go through and decide what I needed before listing the rest..Everything should be fairly priced to move to a new home garage. Everyone appeared to be happy with the last round of stuff. Let me know if I’m off the farm on anything. **Important** All Paypals need to have the buyers screen name, the items they are buying and the shipping address listed in the notes. If not they will be refunded because it’s a huge PITA to keep straight with this many items. Thanks guys! (and gals, I have learned). Keep on turning those wrenches!!! REDUCED PRICE Factory front and rear sway bars-Need new bushings but include all links as well as the insanely expensive balled shock bolts. $400 (shipping included) Steering wheel and horn pad- It’s the 380MM wheel! Needs to be recovered. Had planned on doing leather. Pad is crazy nice with no broken ears. $125 (shipped) Brakes Front and rear- Fronts are the bigger calipers. Painted red (uggg failing paint) both F&R worked great and have nearly new pads. Include lines $200/set (shipped) Targa Bar Bright work Trim-Very nice. Only missing Pass side rear sail trim, $60 Set of Dash Swithches-$75 (shipped) Speaker housings with newer Speakers, No broken tabs-$50 SOLD Bottom Dash Pad- Fantastic condition, aluminum trim, Side vents included. Two small splits inder glove box..1/16 inch. Invisible unless looking for them. $80 (figure about $20 shipping in the US.) Relay Board, Relays and Cover, 73 2.0- $50 Heater Blend boxes (front), Defrost vents and lower vents Very nice finish on metal $65 Cabin Heater Controls $60 (Shipped) Rear Lights-Pair-(no lenses) VERY nice Finish. Very little distortion around centers. One outside reflector. $75 (Shipped) 1.7/1.8 Engine Tins, Set. Nice shape, Been painter. $75 Rocker Jack post supports. New. In Primer $20 (Shipped) SOLD Stainless Rockers, No jack holes. $50 SOLD OEM Steel Rockers. A little rough but should be fine with a blast and paint. $50 Center Seat pad with flip up lid. Rip in top, otherwise very nice $20 Headlight Motor Set $50/pair Headlights Complete mechanism, bulbs, motors, surrounds, covers, trim, all hardware. Nice set to restore or paint to match and use as is. $150 Transmission Speedo drives $25/ea (shipped) Clutch fork 915/901 $20 Back Pad for dual adjustable seats. Has couple rips. Board is good. Fix or use for parts, recover, custom. $80 Seat rails (PAIR)-and all hardware, missing one adjuster handle, 1 new one though. $80 Heater Control Boxes (Clam shells) Surface rust on one. Both function and spring correct. $55/pair (shipped) Silver dot gauge cluster- 150mph speedo. Decent shape could use a resto $100 (Shipped) Silver Dot 73 only Multi-gauge $150 (shipped) Wing Windows frame and Rubber- Include hardware, nice shape. $45 (pair) Side Window glass $40 ea. Widow Regulators $30/each Targa Top- Latches, chipped corner, Good Headliner and underside chrome. OK Shape for driver $65 (figure on at least $50 shipping). Rear Trunk lid- Very clean $75 (Local preferred) Door Shells, fairly clean, $75/ea Dash Frame (buck) Clean $50 Door cards, one split in top roll, all metal hangers intact. Nice condition front and back $50 Outside Door Handles, Locks, Trunk button and front trunk handle,cable and lock. OEM black Key. $150 Door sill alum plates $30 Round side marker lights, seals and un-cracked lenses, buckets (might be new lenses) Hella $40 (Shipped) |
Lo-Fi Version | Time is now: 15th May 2024 - 07:37 PM |
