Replacing rear brake soft lines |
87m491 |
Sep 18 2016, 11:02 AM
Member Group: Members Posts: 274 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Does anyone have a preferred "shortcut" for removing the retaining "U" tab on the soft line mounts to the body? The bottom ones behind the wheels are a snap as there is plenty of remove to lever with a screwdriver or other, but the upper side which is up at the edge of the engine bay has very little maneuvering room to get a tool in, on , around.
thx Mike |
stugray |
Sep 18 2016, 11:58 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
IIRC I use a small pair of vise-grips and clamped onto the raised portion of the tab.
Then I used a screwdriver tho pry the visegrip head away from the brake line fitting. |
Lo-Fi Version | Time is now: 18th May 2024 - 04:26 AM |
