FS NEW Powder coated Engine bar to body brackets $30 a pair shipped |
bdstone914 |
Sep 29 2016, 12:43 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Three sets still available still.
I have several pairs of these made after seeing that most of them are badly bent from dropping the trans down without loosening the bolts in the engine bar brackets. They are made to the same dimensions with a slotted center hole. Made from mild steel and powder coated satin black. $30 a pair shipped. Attached thumbnail(s) |
74ravenna |
Sep 29 2016, 01:25 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
I'll take a pair.
PM Sent |
bdstone914 |
Sep 30 2016, 07:41 AM
Three sets sold, thre sets still available.
Jett |
Sep 30 2016, 08:29 AM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I'll take a set as well please.
PM sent |
michael7810 |
Sep 30 2016, 11:26 AM
Senior Member Group: Members Posts: 1,080 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Where exactly do these go? My car is a 72 with side shift conversion and I'm sure it does not have these. Thanks
marksteinhilber |
Sep 30 2016, 11:42 AM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
bdstone914 |
Sep 30 2016, 11:57 AM
Where exactly do these go? My car is a 72 with side shift conversion and I'm sure it does not have these. Thanks How does the engine bar mount to the body? I have seen conversions done wrong using the original tail shift mounts and then cut down the engine bar ends. They bolt to the engine mount console. The ends of the bar bolt to the center hole in the bracket. |
michael7810 |
Sep 30 2016, 02:27 PM
OK. Duh. I have them, I never paid attention to what the bar bolts to.
Thanks |
914bub |
Sep 30 2016, 05:17 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
OK. Duh. I have them, I never paid attention to what the bar bolts to. Thanks Bruce Are these the only brackets that differ from a tail shift engine mount bar? in other words I have a side. shift engine mount bar but not the brackets that go at the ends. For some reason I thought the ones I needed were like a square, steel "box". If these are the ones I need ill take a pair. |
bdstone914 |
Sep 30 2016, 05:27 PM
Bruce
Are these the only brackets that differ from a tail shift engine mount bar? in other words I have a side. shift engine mount bar but not the brackets that go at the ends. For some reason I thought the ones I needed were like a square, steel "box". If these are the ones I need ill take a pair. [/quote] You also need the engine to rubber mount brackets. The tail shift uses a one piece bracket and side shift uses two brackets. A little hard to see but the orher brackets are in the picture near the center rubber mounts. Attached image(s) |
bdstone914 |
Nov 9 2016, 09:05 PM
Bump
bdstone914 |
Nov 25 2016, 10:27 PM
Lo-Fi Version | Time is now: 5th May 2024 - 06:19 AM |
