3.2 Carrera Engine Fitment Into a 914/4, What installation problems to consider. |
tach |
Oct 28 2016, 01:10 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
I have a 1987 911 3.2 carrera engine I would like to install into a 74 914.
1. Will the engine fit with out chopping up the engine compartment? 2. Will the 901 trans and starter bolt on 3.2 engine. 3. Flywheel clutch pressure plate, what works. 4. What other modifications/issues should I consider installing this engine. Thanks. |
Tom_T |
Oct 28 2016, 01:18 PM
While not in a 914, I do know that Porsche built 17 VW Vanagons with the 3.2L Carrera motor (& they too were just a 1.9 or 2.1L WBX flat-4 in a tight engine bay), along with all the 911 running gear & sold them for 100,000+ DM (more than their price-topping 928 then). You can find info on them if you google for Porsche B32 Carrera.
I'm sure some on here have done the 914 3.2 build, so hopefully they will chime in, plus you can do a google search for it, & actually get more/better hits in 914world, than with the internal search function on here. PS - It should be the same engine fit as the other Porsche aicooled 6's into a 914-6 conversion, but I'd recco using the 5-speed trans that came with the 3.2 Carrera (G50 IIRC), if it can be "turned-around" for mid-engine use. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Oct 28 2016, 01:32 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have a 1987 911 3.2 carrera engine I would like to install into a 74 914. 1. Will the engine fit with out chopping up the engine compartment? 2. Will the 901 trans and starter bolt on 3.2 engine. 3. Flywheel clutch pressure plate, what works. 4. What other modifications/issues should I consider installing this engine. Thanks. 1. Yes but if i recall correctly you have to flip the intake to prevent the throttle body from hitting the trunk or do some modifications to the upper intake system. 2. Yes but i'd suggest getting a high-torque starter. 3. There are several threads on how adapt a /6 to a 901. For my 3.6L, KEP (Kennedy Engineering) had all the needed parts (sans the actual flywheel). 4. Depending on where you live and what kind of driving you're aiming for, you may need additional external oil cooling. I know of several 3.2L conversions that run just fine with only the stock oil cooler but those are all street cars. 5. You'll have to figure out what to do for an oil tank. 6. You need to mate the 3.2L engine harness to your 914 chassis harness. I think PMS (Patrick Motorsports) makes a conversion adapter for the 3.2L, they do for the 3.6L. 7. Custom or 914/6 throttle cable. 8. Custom or 914/6 shift rod. 9. Better brakes to deal with the increased power. 10. Wider wheels and tires to deal with the increased power. (IMG:style_emoticons/default/smash.gif) |
tygaboy |
Oct 28 2016, 02:15 PM
914 Guru Group: Members Posts: 5,294 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Take a close look at what Sir Andy outlined. It's a ton of work - really, I'd advise against it. You'd be far better off selling the 3.2 to me! (IMG:style_emoticons/default/happy11.gif)
Kidding, of course. There are any number of threads here that'll cover 'bout everything you can think of on your conversion. Best of luck with the build and let me be the first to say: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
JmuRiz |
Oct 28 2016, 02:56 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
tygaboy, I was thinking the same thing....the 3.2 is great in a 914 if it's done well (as Andy laid out in his post).
Don't short cut it and it will be amazing! |
Oct 28 2016, 07:20 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a 1987 911 3.2 carrera engine I would like to install into a 74 914. 1. Will the engine fit with out chopping up the engine compartment? 2. Will the 901 trans and starter bolt on 3.2 engine. 3. Flywheel clutch pressure plate, what works. 4. What other modifications/issues should I consider installing this engine. Thanks. 1. Yes but if i recall correctly you have to flip the intake to prevent the throttle body from hitting the trunk or do some modifications to the upper intake system. 2. Yes but i'd suggest getting a high-torque starter. 3. There are several threads on how adapt a /6 to a 901. For my 3.6L, KEP (Kennedy Engineering) had all the needed parts (sans the actual flywheel). 4. Depending on where you live and what kind of driving you're aiming for, you may need additional external oil cooling. I know of several 3.2L conversions that run just fine with only the stock oil cooler but those are all street cars. 5. You'll have to figure out what to do for an oil tank. 6. You need to mate the 3.2L engine harness to your 914 chassis harness. I think PMS (Patrick Motorsports) makes a conversion adapter for the 3.2L, they do for the 3.6L. 7. Custom or 914/6 throttle cable. 8. Custom or 914/6 shift rod. 9. Better brakes to deal with the increased power. 10. Wider wheels and tires to deal with the increased power. (IMG:style_emoticons/default/smash.gif) A $10 extension from pep boys will let you fit a stock 3.2 air box into the engine bay without flipping or cutting. There are threads for this and the entire engine swap on this site. Actually there are many 3.2 conversion threads if you just do a search. You will be into the conversion for about $10-15k not including the engine or cost of labor. More if you want all the high end parts and brakes, wheels, tires, flares and 915 trans. There is no G50 trans conversion unless you are getting something custom made with cable shifters. |
pbanders |
Oct 28 2016, 07:42 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I have a 1987 911 3.2 carrera engine I would like to install into a 74 914. 1. Will the engine fit with out chopping up the engine compartment? 2. Will the 901 trans and starter bolt on 3.2 engine. 3. Flywheel clutch pressure plate, what works. 4. What other modifications/issues should I consider installing this engine. Thanks. FWIW, I would call Patrick Motorsports on the phone and talk to Jim Patrick about what you're planning. They've done a lot of this type of conversions, and the manufacture all the custom pieces you will need. Not cheap, but high quality. There other sources, too, I'm sure other people here can fill you in on the other options. (602) 244-0911 |
ConeDodger |
Oct 28 2016, 08:09 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Call McMark at Original Customs. He did my 3.2 conversion. And, he's not too far from Minnesota!
ClayPerrine |
Oct 28 2016, 08:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There are adapter flywheels out there for the 215mm clutch that is used in the 914. If you use the 901 from a 70 or 71 911, it uses teh 225mm clutch, same as the 3.2 engine. So it all bolts together.
And you can't flip the ring and pinion on a G50. The case design doesn't allow it. But you can run it upside down. But that will screw up the axle geometry and it will hit the bottom of the rear trunk when you try to put the engine in correctly. 915 with a wevo or 916 kit is the best bet for a 3.2. |
Steve |
Oct 28 2016, 08:40 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Very simple swap. I did mine 16 years ago, by myself in the garage, with a 914 and 911 Haynes manual.
I am not a mechanic by trade. My profession is IT Some of the parts... -914-6 tin -3.2 tachometer and gauges -front trunk mounted 3.2 pump -Kennedy stage two adapter ring and clutch (for use with 914 trans) I upgraded later to a 916 trans, to get the correct gearing for street. -PMS front oil cooler and Getty design Gt shroud -stock 914-6 oil tank -rich Johnson motor mount and throttle cable assembly -made my own wiring harness. -pep boys air flow meter extender. -1 5/8" MSDS headers -911 muffler -PMS shift rod or have one made. -Also check out CFR's 914-6 shift rod, bushings and other 914-6 stuff. Check out the member vendors forum for links or use google for there web sites. If you have the money I would also use Mcmark |
jim912928 |
Oct 28 2016, 09:58 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I put a 3.2 in mine (search jim912928 for write up on wiring and fuel conversion). I didn't flip my throttle body and use the stock air box. Wasn't a hard conversion. I run 901 tranny...just had to notch it for the sensors.
eitnurg |
Oct 29 2016, 02:06 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
What they said. I used (many years ago now) PMO Webers - which solved some problems, but introduced others - and a 901 side shifter trans (the shift rod was simply bent straight(er), and then shortened to suit.) Relatively straightforward, the issues that I remember were:
1) HE pipe diameter is critical. No matter what is said, the original 914/6 version is too narrow & reduces power and max rpm. 2) the 3.2 runs a much higher CR - and thus reduced ign advance - than any previous 911 engine (or at least the Euro one does), all ignition is dealt with by the Motronic box, the distributor just points to various cylinders, it has no advance mechanism in it. You can't just substitute an earlier distributor (too much advance), and also ISTR a direction of rotation issue. After many years messing around with a succession of magic boxes, I ended up getting an early distributor re-curved - a virtually vanished art these days. |
sled9146 |
Oct 29 2016, 09:50 AM
Member Group: Members Posts: 64 Joined: 7-July 06 From: Granite Bay, CA Member No.: 6,395 |
Ditto Sir Andy
I changed to the latest "901" aka 1970/71 911 transaxle to get the 10mm larger clutch. Just use first gear to get moving and then 2-5 for full acceleration or you will be replacing mainshafts Recommend converting to "GT" engine lid with full mesh and front oil cooler and you should not have any cooling problems |
MoveQik |
Oct 29 2016, 02:02 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
The motor will fit perfectly. :-). Tons of great tips offered above.
Attached thumbnail(s) |
Steve |
Oct 29 2016, 03:34 PM
Love my 3.2 with Stock DME fuel injection. I miss the sound of the webers, but I don't miss the hassle of clogged jets and tweaking. The 3.2 also has an altitude sensor to automatically adjust for different elevations.
mb911 |
Oct 29 2016, 03:40 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Between rich Johnson and I we can supply you with all the required conversion parts.. Its well worth the time. Very fun with a 3.2
patssle |
Oct 29 2016, 05:37 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Here's my 3.0L build photo album: http://imgur.com/a/k0Wtl
boxsterfan |
Oct 29 2016, 09:59 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
The biggest installation problem with a 3.2L in yoru 914 is callled a "reverse installation" or exit problem. Basically, you have a hard time exiting the driver's side door due to the gigantic grin on your face.
PanelBilly |
Oct 29 2016, 11:07 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Looks like it can't be done
shoguneagle |
Oct 30 2016, 07:58 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
It appears you have everything in various combinations to get your conversion; you have all the basic resources at your finger tips, etc.
The only thing not covered is the electrical wiring connections (in case Patrick adaptor is not the way you want to go. The alternate is to change the pin wiring on the 14-pin connector in the engine compartment. Either adapt the engine wiring harness to the car wiring or car wiring to engine harness. time consuming but very straight forward to do and then the attaching of the engine harness into the car harness - again very time consuming but straight forward. The are considerable threads regarding the conversion: information sources, parts, people who have done it, etc. You will enjoy the project and the eventual driving of the car. Does not get any better than that except carving up the road curves or race track. Have Fun! Steve |
Lo-Fi Version | Time is now: 18th May 2024 - 08:07 PM |
