| bcheney |
Nov 27 2016, 02:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
| jmill |
Nov 27 2016, 03:07 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The guy selling them has done some nice work. I remember a suby powered Boxer that was quite nice.
| Mueller |
Nov 27 2016, 04:33 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
| mb911 |
Nov 27 2016, 05:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
The guy selling them has done some nice work. I remember a suby powered Boxer that was quite nice. ^ditto, great deal on those axles, oh so tempted since I happen to have a Boxster transmission as well.... Would that bolt up to a Porsche 6 (aircooled)? Boxster trans I am talking about. |
| jmill |
Nov 27 2016, 06:28 PM
Ask him. The thread below is his work with the Boxter. He did a couple of awesome 914's too.
http://www.914world.com/bbs2/index.php?sho...=109434&hl= |
| dflesburg |
Nov 28 2016, 07:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
IMO
you have to spend a lot of money to make a 914 drive as well as a nice used Boxster S. |
| Mueller |
Nov 28 2016, 07:58 AM
The guy selling them has done some nice work. I remember a suby powered Boxer that was quite nice. ^ditto, great deal on those axles, oh so tempted since I happen to have a Boxster transmission as well.... Would that bolt up to a Porsche 6 (aircooled)? Boxster trans I am talking about. I started to draw something up [on phone, cannot find thread I started] Clay is working on his version and more than likely get his done 1st. |
| ClayPerrine |
Nov 28 2016, 06:16 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The guy selling them has done some nice work. I remember a suby powered Boxer that was quite nice. ^ditto, great deal on those axles, oh so tempted since I happen to have a Boxster transmission as well.... Would that bolt up to a Porsche 6 (aircooled)? Boxster trans I am talking about. I started to draw something up [on phone, cannot find thread I started] Clay is working on his version and more than likely get his done 1st. I just came in from the garage where I was working on a wooden mockup of the adapter plate. I had to stop because I let the magic smoke out of my dremel trying to cut the center out of the wooden mockup. Here is a picture of the adapter plate dimensions. ![]() This was a bitch to create. Lots of time researching it, and lots of time testing and combining the drawings. I have made 4 separate wooden mockups. I had one hole slightly off on the last one. And I still have to make the cutout for the DME sensor. I am going to go try to make the first one later this week. Wish me luck. (IMG:style_emoticons/default/biggrin.gif) Mueller... if you want to try it, go for it. I have to go borrow some time on a Bridgeport to make this. For Reference, here's the G86 bolt pattern diagram I found on the internet. ![]() Once I make the plate, I am going to pull the engine off the stand and test it. Honestly, I wouldn't go to the trouble if it wasn't a 6 speed, or I could flip the ring and pinion on a G-50 gearbox. |
| Miguel K R |
Oct 26 2020, 02:06 PM
Newbie ![]() Group: Members Posts: 20 Joined: 12-December 19 From: Portugal (Europe) Member No.: 23,732 Region Association: None |
I am adapting a G87 trans from a Boxster/Cayman S to an air cooled engine (from a 993 but with 964 inlet manifolds to fit under the engine lid).
I will use a flywheel from Kennedy Engineered Products and found that the adapter plate must be 20mm thick. I started by printing a 1/1 scale drawing of the G86 Porsche/Audi bellhousing bolt pattern available at https://grabcad.com/library/01e-audi-transm...-bolt-pattern-1 1) I noticed that the above mentioned drawing does not include one fixing hole which I will use with the G87 trans . I will mark this hole and drill it when I get the adapter plate and check the mating of the trans to the engine. I will then update my CAD file. 2) These drawings still do not present the cutout and fixing for the hightorque starter. I will post the final drawings when I complete that detail. 3) I did not consider the cutout for the DME sensor because I am not using it . I am running the engine with a programmable Engine Management System (with wasted spark : https://en.wikipedia.org/wiki/Wasted_spark ). I am not going to add the detail for the DME sensor to my drawings and CAD file, but that is presented by Clay Perrine at http://www.914world.com/bbs2/index.php?sho...204.0&st=80 (see Post #91). The preliminary drawing of the adapter plate is available at : https://photos.app.goo.gl/WdHfUvdgCfWJFz4g9 |
Lo-Fi Version | Time is now: 22nd September 2026 - 05:49 PM |
