Front Suspension 'Jig', Looking for dimensions to fabricate |
Bates |
Nov 29 2016, 02:09 PM
Bates Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
I am in need of a front suspension jig measurements to fabricate one.
I need the angle of the front suspension points particularly, also the center to center measurements from the front diagonals to the mid suspension bosses. Thanks for any help, diagrams etc. |
mb911 |
Nov 29 2016, 04:32 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am in need of a front suspension jig measurements to fabricate one. I need the angle of the front suspension points particularly, also the center to center measurements from the front diagonals to the mid suspension bosses. Thanks for any help, diagrams etc. I know jmill has one. |
jmill |
Nov 29 2016, 07:05 PM
http://www.914world.com/specs/underdims.php
I made one. The price to ship would be way more than it's worth. Best bet would be to find someone with a straight 914 and Make one. Check my sig for pics of how I did it. It's ugly but functional. Added pic so you don't have to search for it. I had a rusty but straight front clip to work off of. Attached image(s) |
Bates |
Nov 30 2016, 09:03 AM
JMill, Thanks. Your chassis had the same issue I am facing. Front of right suspension is about 3/4" higher than spec, front of that fender needs replacing.
I agree about shipping and the jig, I'll be making one similar to yours based on factory dimensions and the two cars I have here to measure. The fore/aft dimensions on my car are still correct, front is just raised, the floor is riased at and angle going back to the fuel tank bulkhead. The driver's side looks perfect, so that measurement will be my control (car is currently on a rolling cart, hard to get an accurate measurement, the donor car's front end has been removed, so pretty easy to get accurate measurements. I measured the angles of my donor car, which has not been hit, but has a fair amount of rust in some areas, and the front suspension mounts measure 11-12 degrees on both side from level. I'll post pictures on my next post. Thanks again. |
Lo-Fi Version | Time is now: 21st May 2024 - 07:47 PM |
