10 Pages V « < 8 9 10
> How to inspect the underside and longs without a lift, - Exhaust shield some assembly required
seanpaulmc
post Apr 3 2026, 05:43 PM
Post #181
To install the tail light for trial fitting I still have to finish trimming and welding of the inner fender. The white line is about where it’s needs to be cut back.
Trimmed out of the way.
Considering the hackery involved with “repairing” this corner of the car, the fit of the replacement tail light is pretty good.
This is with the bolts holding the light assembly slightly tightened.
The fit is good but there is a gap in the top edge which I think is mostly due to me removing the lead in this joint before I had a real plan for this corner. It will need to be re-leaded to complete the joint anyways.
Being a first timer at this I can work with this.
930cabman
post Apr 3 2026, 06:34 PM
Post #182
I would consider sealing the light/body intersection with a sealant of your choice.
I like Dow Corning 756 paintable silicone
seanpaulmc
post Apr 12 2026, 06:29 PM
Post #183
This weekend worked on finishing up the quarter panel donor replacement with some grinding and patching.
You remember the original tail panel piece that was removed.
There's still some life to it. I'll just take this little piece here.
And put it right here.
I think all the big holes are done now.
seanpaulmc
post Apr 12 2026, 06:52 PM
Post #184
I am pretty happy with the outcome of the quarter panel graft. It certainly exceeds my expectations (there weren't any). I mean, it really couldn't have been any worse than the last guy, right? If you don't believe me, go look at post 125.
Since the layering of filler on both the existing panel and the donor panel make it hard to visually check the straightness of the welded seam, I used a small straight edge to check it.
It could benefit with a little more hammer and dolly work or a planishing hammer (don't have) but it is surprisingly not terrible. And it will certainly use a lot less than the gobs of filler that were on this panel when I got it.
It was back in post #142 that I got the nerve to take the offending quarter panel off. It feels good to have it back together finally.
Still working to make this a solid tub. Body and paint will be some time off in the future. Recall it was in post 122 when I started ripping into this trunk with all it's rotten metal.
friethmiller
post Apr 12 2026, 08:20 PM
Post #185
Boss! (IMG:style_emoticons/default/first.gif)
Montreal914
post Apr 12 2026, 10:05 PM
Post #186
Looking good! (IMG:style_emoticons/default/smile.gif)
seanpaulmc
post Apr 18 2026, 06:42 PM
Post #187
For the two of those who might be paying attention here's the latest update.
Lest we forget where we started, here is the removed, original trunk pan.
I understand the body number is supposed to be stamped into this trunk pan but I can't find it. As you can see this panel has been consumed by the tin worm.
So I've got a good section of replacement trunk metal that I got from Eric and I've already fitted it before going down the rabbit hole of the quarter panel job. However, there are still some details to do before welding in the trunk pan.
The exhaust shield also needs to be resurrected and attached to the trunk pan in order to avoid welding on my back underneath the car as much as possible. I've decided to make the exhaust shield bolt on with inspiration from Bob's build but have modified it to my own craziness. Here's what we start with.
The brackets, new and old. Conjured, fabricated, and assembled.
Two ends and a center support.
Bob's method was easier. I don't know why I make things harder on myself.
I am pleased with the results.
Looking forward to having the trunk pan installed one of these days.
porschetub
post Apr 18 2026, 09:19 PM
Post #188
Mines a 73 and I can't find those numbers on that panel and my car is low mileage and very original ,don't know the answer to this ...someone may know ?? TIA.
930cabman
post Apr 19 2026, 07:14 AM
Post #189
FYI, the RD trunk panel is a close match to the early cars, later cars require some creative fitting/welding at the rearmost corners
seanpaulmc
post Apr 19 2026, 05:33 PM
Post #190
I told myself I wasn’t going to fix it. Leave it alone. It just isn’t worth it.
Weld repair on the exhaust shield. The exhaust shield that no one anywhere is going to see or care about!
I want to know when does the crazy take root? Am I just predisposed, is it the inhalation of rust dust from all the grinding repair work, or have I been working out in the sun just a little too long? Sheesh! (IMG:style_emoticons/default/screwy.gif)
friethmiller
post Apr 19 2026, 06:07 PM
Post #191
QUOTE(seanpaulmc @ Apr 19 2026, 06:33 PM) *
Well done! Yep! It had to be fixed. No doubt in my mind. I don't see what the big deal is here. LOL! (IMG:style_emoticons/default/happy11.gif)
Montreal914
post Apr 19 2026, 11:11 PM
Post #192
QUOTE(seanpaulmc @ Apr 19 2026, 04:33 PM) *
The exhaust shield that no one anywhere is going to see or care about! I want to know when does the crazy take root? Am I just predisposed, is it the inhalation of rust dust from all the grinding repair work, or have I been working out in the sun just a little too long? Sheesh! (IMG:style_emoticons/default/screwy.gif)
I was recently thinking similarly. (IMG:style_emoticons/default/idea.gif)
Crazy how much our philosophical minds can run while spending all of this time working on these.
I concluded there is no crazyness here, only satisfaction of work well done and high personal standards. (IMG:style_emoticons/default/sunglasses.gif)
Before you know it, someone else will ask you: I think my heat shield is getting rusted, how is the one on your car? (IMG:style_emoticons/default/laugh.gif)
930cabman
post Apr 20 2026, 04:44 AM
Post #193
QUOTE(Montreal914 @ Apr 19 2026, 11:11 PM) *
OCD (IMG:style_emoticons/default/idea.gif)
seanpaulmc
post Nov 7 2026, 08:51 PM
Post #194
Got this in today…
Finally!
50 User(s) are reading this topic (50 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th November 2026 - 09:54 PM
