Another "new" parts Didn't know these existed, Bumper top spacers |
Mikey914 |
Feb 17 2017, 12:24 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes it was brought to my attention that what I thought were simply washers are indeed rubber spacers! Makes sense now. These are going to be available next week, Did a short run to test, but it helps with the fitment.
Attached thumbnail(s) |
SixerJ |
Feb 20 2017, 09:27 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Mark, here you go. I got these before Christmas in a shipment of lots of NOS stuff for the -6
OD 14.0mm ID 4.9 to 5.0mm depending on where and which washer you measure Height / length? 6.4 to 6.7mm again depending on which washer you measure If you look really closely at the picture it looks as if these have been sliced to length rather than individually moulded and spat out In terms of material hardness if you squeeze as hard as you can between thumb and forefinger across the OD you can deflect the rubber and squish out to 14.5mm max. Obviously not an SI based measurement technique, but gives you an idea of what to make them from |
Lo-Fi Version | Time is now: 29th April 2024 - 02:02 AM |
