Carpet won't fit., Something missing? |
Pugbug |
May 4 2005, 02:44 PM
Member Group: Members Posts: 449 Joined: 14-February 05 From: Victoria, BC Member No.: 3,604 |
I've just installed a carpet kit from Pelican..The piece on the floor of the passenger side doesn't fit. Appears to be about 6"" short.
I contacted Pelican, and was told that it was correct, and that there is supposed to be a peice of hard moulded foam that takes up that space. I'm not sure if the foam is part of the kit , or is part of the car. Not a big deal, but I would like it correct. Pic below. Attached image(s) |
iamchappy |
May 4 2005, 02:52 PM
your missing the passenger foam block foot rest
MoveQik |
May 4 2005, 02:54 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
You are missing the foot rest. It is a molded piece of foam that goes behind the carpet on the passenger side. I took the footrest out of mine as well to make for more leg room. As a result, I am trying to find a kit that will fit sans the footrest. So far....no luck. Chances are I will have to have a local shop do all the carpeting.
Good luck and let me know if you find a kit that will fit without the footrest installed. |
JmuRiz |
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Yep you need the foam thing.
Anyone know where he can get one? I always thought it'd be cool to do a matching alumn one to go with my engman alumn pedal board w/ the holes in it (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Kindda like this 911: (IMG:http://forums.pelicanparts.com/uploads5/P10104071114974362.jpg) |
Mueller |
May 4 2005, 02:57 PM
just place an WTB ad in the classifieds...should be pretty cheap...I threw one away a few weeks ago....not a huge demand for them..... you can also do a search for speaker enclosures here if you want to kill 2 birds with one stone (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
morph |
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
I think that we have an extra 72-76 footrest $15 plus shipping, they are a common part, you can find them cheap. Someone local to you might have one.
HIEDI |
Pugbug |
May 4 2005, 03:11 PM
Well I would delete the other post .....If I knew how.. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Deleted....thanks |
Pugbug |
May 4 2005, 03:21 PM
Thanks for the replys guys.....That clears things up. If I can't find the foam piece I'll make something up no problem.
morph |
May 4 2005, 03:25 PM
Footrest foam 72-76, Below is what you are looking for
morph |
May 4 2005, 03:26 PM
sorry forgot to add pic
morph |
May 4 2005, 03:28 PM
foam 70-71, they are all interchangable, but that will determine what year of carpet kit you need
xsboost90 |
May 4 2005, 03:57 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
i have one from a 76, im putting the early carpet in my car. $15+ shipping if you want it, xsboost90@yahoo.com
MoveQik |
May 4 2005, 05:28 PM
If you use a carpet kit for an earlier car will it fit a later car without the footrest? That would be fantastic.
SLITS |
May 4 2005, 05:32 PM
I thought the "rare" foamy thingy only came in the '75 - '76 cars with an EGR counter and two piece speedo cable....
Just get an early carpet kit......... |
mskala |
May 4 2005, 06:36 PM
Know where pretty much the only rust-through on my reasonable
formerly-mid-western car is? Bunch of pinholes under the dang (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) foam! Be sure that area doesn't get wet or get POR-15. |
May 4 2005, 06:44 PM
I believe that the early cars still had the foam piece in the footwell. They had an extra moveable (and removable) footrest that was intended to make up for the non-movable passenger's seat. But I believe they still had the hard foam thing in the front corner of the passenger footwell. --DD |
MoveQik |
May 4 2005, 07:50 PM
Damn! I knew that would have been too easy.
SLITS |
May 4 2005, 09:48 PM
Damnit Dave...now I gonna go tear apart my two '73s and two '74s and one '70 just to see. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Pugbug |
May 4 2005, 10:36 PM
My car is a 75. Is it supposed to have the footrest?
Pelican e-mailed me today. Apparently I glued the piece that was supposed to cover the footrest to the firewall. It fit there perfectly. No big deal I have enough of the same carpet to make a piece to fill the gap. The engine and tranny are going in tomorrow and if all goes well, and I'll be cruising by the weekend. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
May 4 2005, 11:17 PM
Your 75 should have the foam thing that we've been talking about. The footrest is a separate piece, and was only used on 70-71 cars. Not on 75s.
--DD |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 AM |
