Resto-Thread: '73 Marathon Blue 2.0 |
914_7T3 |
Apr 21 2017, 01:28 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
I have been on 914 World for just a few weeks and with the knowledge and support of everyone was able to get up to speed quickly on values and things to look out for. when considering a vehicle to purchase.
I just acquired this matching numbers '73 Marathon Blue 2.0 up in NorCal on Wednesday. Straight car with a strong motor and minimal rust issues. Fuel lines and pump have already replaced and rear suspension and brakes were done about 5,000 miles ago back in 2012. The required rust repairs of significance will entail a partial front trunk pan and minor hell hole repair so in the grand scheme of things a great starting point. My plan is to get her tuned up, fix oils leaks and anything else of concern while I drive her over the summer. Once fall/winter hits I would like to do a full repaint down to the metal. Special shout out to Arne as well as Craig from Camp 914 for the behind the scenes consults. Also shout out to John at Hayes European in Santa Cruz for the PPI! Wish me luck! |
arne |
Jul 16 2017, 07:38 PM
Serial Rescuer of old vehicles... Group: Members Posts: 734 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Whether to do just the top end or the whole enchilada at this point is a hard call. If it is in fact burning oil badly, at a minimum rings and valve guides need to be addressed. At that point, if oil pressure is good (indicating good bearing clearances) you could leave the bottom alone. Could still bump the compression and displacement while at it, but I'm not thinking that would be satisfying with the stock cam.
The performance aspect is what clouds the decision. If there was no desire to boost the output, top end only would be my choice. But trying to get more HP without splitting the case to change the cam doesn't seem viable. |
iankarr |
Jul 16 2017, 08:34 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Whether to do just the top end or the whole enchilada at this point is a hard call. If it is in fact burning oil badly, at a minimum rings and valve guides need to be addressed. At that point, if oil pressure is good (indicating good bearing clearances) you could leave the bottom alone. Could still bump the compression and displacement while at it, but I'm not thinking that would be satisfying with the stock cam. The performance aspect is what clouds the decision. If there was no desire to boost the output, top end only would be my choice. But trying to get more HP without splitting the case to change the cam doesn't seem viable. (IMG:style_emoticons/default/agree.gif) If you're just looking to get it tightened up and back on the road, The top end refresh is what I'd do. Did it myself and had no regrets. |
914_7T3 |
Jul 16 2017, 10:10 PM
Whether to do just the top end or the whole enchilada at this point is a hard call. If it is in fact burning oil badly, at a minimum rings and valve guides need to be addressed. At that point, if oil pressure is good (indicating good bearing clearances) you could leave the bottom alone. Could still bump the compression and displacement while at it, but I'm not thinking that would be satisfying with the stock cam. The performance aspect is what clouds the decision. If there was no desire to boost the output, top end only would be my choice. But trying to get more HP without splitting the case to change the cam doesn't seem viable. (IMG:style_emoticons/default/agree.gif) If you're just looking to get it tightened up and back on the road, The top end refresh is what I'd do. Did it myself and had no regrets. This is what I'm leaning towards and I am more than fine with the present 1,971 displacement. |
Lo-Fi Version | Time is now: 28th April 2024 - 05:24 PM |
